checking for fuel leaks?
Old Dec 4, 2008 | 09:51 PM
ctdnwakulla's Avatar
My 97 3500 sat up for about 4 days.When I returned and tried to crank it,I had difficulty starting.I had to bleed the fuel lines to get started,I suspect a slow fuel leak and was wondering what you think is the best method to detect this. I am thinking about dye and blacklight as the leak is'nt obvious.Would like your input,thanks.
Old Dec 5, 2008 | 11:30 PM
rebal's Avatar
I used 5 psi air in the fuel tank to find all but 1 leak and it turned out to be the filter drain it leaked under vacuum
Old Dec 6, 2008 | 11:12 AM
infidel's Avatar
I always use the air method also.
So much so that I have an old fuel tank cap with an air fitting tapped into it.
Also works excellent to fill and bleed the system after a filter change, no more pumping the primer button 200 times.
Old Dec 6, 2008 | 11:56 AM
BigIron70's Avatar
Cummins Guru
If you have a 97 diesel it most likely is fuel return line that it located left rear of engine. A real $#@% to get to. I would suggest removing two bolts that hold the steel lines return and supply together on the transmission. The loosen both hose clamps from engine. Pull fuel lines down and remove with steel lines still attached. Then you can replace both hoses at same time. 5/16 hose longer hose and 3/8 supply fuel hose. Good Luck
justagoodolboy
Sep 7, 2022 12:43 PM
LongBlackRam
Aug 17, 2013 12:57 AM
abchoppers
Jan 26, 2011 05:38 AM
mr T
Apr 24, 2005 12:25 PM
