Check Gauges Light Flashing
Alternator Gauge shows Low Charge
Alternator gauge shows low voltage,and the dash has a CHECK GAUGES light flashing for the first couple minutes, now slow starting, should I just replace the alternator, or look for something else? put brand new batteries in a few months ago.
Get the alternator tested, most autoparts do it for free.
If it turns out the PCM regulator is bad not to worry, you can add an external regulator without replacing the PCM for under $25.
Instructions> https://www.dieseltruckresource.com/...n&onlynewfaq=1
Instructions are for 1st gens but work on all.
04 SO CA
05-13-2004 11:31 PM
04 SO CA
04-24-2004 03:27 PM
Hummin Cummins
24
07-17-2003 12:50 AM
