Can I swap for a 2nd/3rd gen fuel filter ?
Old Feb 16, 2009 | 08:34 PM
Valv's Avatar
Can I swap for a 2nd or 3rd gen fuel filter housing instead of my old style type ?
Old Feb 17, 2009 | 07:48 AM
patdaly's Avatar
Should be able to go to the 97-98 12V style with no issues, but the question is , why?
I would rather have a spin on any day of the week.
Old Feb 17, 2009 | 09:43 AM
gmctd's Avatar
Yes - the top-loading filter is very user-friendly, with it's drop-in convenience - you will need to modify the fuel pipes incl the injector fuel-return pipe - compare your spin-on system with the top-loading cannister, noting the lengths and fittings on each pipe - helps to have the pipes and fittings from the later engine - the injector-return pipe can be extended with clamped rubber Diesel-fuel hose - installation will require repositioning of the main engine harness for easier top-loading access - the first version mounts like the 12v filter head, where the 90* angle bolts to the top of the intake manifold - the later versions, without the 90*, mount to the side of the intake manifold - the early version cannister is cast to accept the lift pump - the later versions are cast for use with the in-tank lift pump
Old Feb 17, 2009 | 10:07 AM
infidel's Avatar
If you're going to go though the hassle why not just convert to the type John Deere uses?
No bolts, no spinning. Filter is glass with two o-ringed ports on the back that push down onto two nipples. A spring loaded bracket snaps over it to hold in place.
Changing a filter takes five seconds max...
Old Feb 17, 2009 | 07:21 PM
Valv's Avatar
I have 8 2 micron filters leftover from my 3rd gen, I was going to reuse them, besides I think the new design is much better. I might relocate it too to be able to access it easily.
Old Feb 18, 2009 | 09:08 AM
patdaly's Avatar
Hadn't thought about the top loading style, is there a way to drain the fuel from the housing before you pull the filter?
Old Feb 18, 2009 | 11:06 AM
gmctd's Avatar
WIF drain is a simple lever-action valve port.............
Old Feb 18, 2009 | 06:37 PM
Valv's Avatar
Patdaly, if you have a little time stop by a dealer and check the new trucks. They have same canister, you'll see how to drain fuel before replacing it.
anonymous_1
13
Apr 30, 2020 04:29 PM
wingrider
Jun 4, 2008 09:48 AM
kammak
Dec 14, 2007 08:48 PM
JohnnyH
Dec 5, 2005 01:55 AM
ARAcummins
Feb 11, 2003 08:41 PM
