Can I sneak on a lower tie rod w/o an alignment?
Old Nov 17, 2008 | 06:12 PM
Common's Avatar
If I count the threads?
Old Nov 17, 2008 | 06:43 PM
gorms's Avatar
If I do just one end, I never get an alignment. I usually check the length from a set point on the rod to the new end, I've found some end manufacturers thread a little bit more or less than others on the rod, throwing the counting meathod out the window. Then I just double check front and rear toe with a tape measure and a piece of wire marked at the lengths. So far it's worked pretty good for me, starting with a good alignment of course.
Old Nov 17, 2008 | 08:52 PM
olwhitey's Avatar
i agree with gorms. u should be able to measure tire to tire on both the font and back of the front tires. make sure u use the same point on the tires consistently so u dont throw off ur measurements. then when u put the new tie rod on, u can just measure the tires again to make the match the old measurements. or if it wasnt aligned in the first place, even out the front and back measurements!
Old Nov 18, 2008 | 05:10 PM
Common's Avatar
I took the old one off and measured grease fitting to grease fitting, - did that to the new bar.
Straight as an arrow!
ddestruel
Dec 7, 2008 06:37 AM
Original Junior
Jun 3, 2006 12:20 PM
mr T
Apr 2, 2006 02:31 PM
Scotty
37
Aug 12, 2004 12:21 AM
Lary Ellis (Top)
Mar 22, 2004 02:23 PM
