A/C clutch
Old Aug 26, 2008 | 07:39 AM
TRCM's Avatar
A/C clutch
anyone know where I can get an a/c clutch ?
Mine has thrown a spring and will not engage. It tries, but immediately releases.
Every place I have called around here sells the compressor without the clutch, but not the clutch without the compressor.
the compressor works fine, but without a clutch, it's a hot beast.....
Old Aug 27, 2008 | 11:52 AM
RAMI's Avatar
a/c clutch
bought mine from ebay 39$$ + shipping.
http://tinyurl.com/4fqcv8 or item number 220060361538
YOU ARE BIDDING ON ONE NEW AIR CONDITIONING SANDEN COMPRESSOR CLUTCH HUB FRONT PLATE FOR 1994-2001 DODGE PICKUP D3500 WITH DIESEL ENGINE. THIS HUB IS FOR A KEYWAY SHAFT, PLEASE BE SURE THAT IS HOW YOURS IS. THIS IS NOT FOR A COMPRESSOR WITH A SPLINE SHAFT. IF THE CLUTCH SURFACE ON YOUR PULLEY IS NOT SMOOTH YOU MAY NEED A WHOLE CLUTCH ASSEMBLY. THANKS FOR LOOKING AND GOOD LUCK BIDDING.
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
