burnt the clutch
Old Dec 16, 2013 | 12:19 AM
Red_Angus's Avatar
Red face burnt the clutch
so as the title says i burnt my clutch, it was rather tragic, id gone into the back 40 to grab some wood i had stacked on a pallet, spun out and spent the next 2 hours lowering tire pressures and rocking the truck. which as more experienced drivers will tell me, was my down fall. sadly i didnt have alot of options.
it still catches, but i know i have severely shortened its life span, i only hope it lives out the winter. i have shifted the afc all the way forward, pulled the fuel plate, the turbo wont push more then 20 psi but when i get that figured out im want it to push 35psi. i have not installed a 3gsk, but it should be planned for. 4in turbo to rear axle, i pushed it out in front of the axle.
the truck is my current DD. i dont tow regularly but i have towed at the limits of the truck, same with payload.
question is what do i replace my clutch with, im pretty sure i havent torched it sooner because of my turbo issue. from what i understand i should be around the 300 HP mark. this pushes me into the aftermarket clutch area, i think. or that i should at least over compensate. i want to make my power without any serious modifications.
Old Dec 16, 2013 | 08:49 AM
patdaly's Avatar
Is it slipping at all right now? I have abused mine pretty good at times, including completely stinking myself out of the cab, and so far, I haven't got it to the point that she will slip in normal operation. I am pretty much 100 percent stock though.
I have a brand new SB DD3250 though, waiting on the time that I finally kill my stocker, I would like roughly the same HP as you, and definitely don't want any clutch issues when i do turn it up.
That's the choice I made, you could probably do with less, perhaps a Con-Ofe ?
Old Dec 16, 2013 | 09:28 AM
Red_Angus's Avatar
I lied. Clutch is dead. Had about 2 miles left in it. Just enough to screw up my day.
Old Dec 16, 2013 | 04:51 PM
patdaly's Avatar
Ugh, worst time of the year to deal with one as well.
I can highly recommend Lary at the DTR performance shop for your clutch though, did me right!
Old Dec 20, 2013 | 06:19 PM
X2 on Lary.
I got the Biggest Single disk from SB [Con OFE?] they make from him 100,000 miles ago, and it still pulling my 10,000# trailer most days
Old Dec 20, 2013 | 06:35 PM
madhat's Avatar
Administrator/Jarhead
Dang it, man. Sorry to hear that.
Old Dec 23, 2013 | 02:10 PM
Red_Angus's Avatar
any suggestions for a mechanic? probably goin to upgrade to a ceramic single disc. would love to do everything for about 1500.
Old Dec 23, 2013 | 10:26 PM
etn550's Avatar
I put a single disc Con OFE in my first '96. Did great. Engagement was good for towing.
Nowadays I think the best towing setup is a Valair double organic disc with the quiet center plate option.
A ceramic disc is like a light switch, on or off. there is no slipping it. If this is a work truck the organic or Fe / Organic is the way to go. The double disc Valair organic will hold a lot of torque. It will be my next one on my "new" '96.
Old Dec 24, 2013 | 12:53 AM
Red_Angus's Avatar
im not expecting to go to deep into the engine, get the turbo makin more then 23psi maybe injectors and timing, that should be it. i dont think ill make more then 450 hp. shes a daily driver with the random tow job. if id been into her already id probably buy another clutch like the one i just destroyed. it was good till i got her stuck and beat the sh't out of it. sigh too bad chains are cheaper then lockers.
nathan76
18
Dec 30, 2010 05:16 PM
Mike D
Oct 4, 2004 04:45 PM
Joseph H. Smith
May 12, 2004 10:07 AM
thumper 549
Jul 14, 2003 06:58 PM
deuceandahalf
Nov 14, 2002 12:05 AM
