break in period,how long???
Hi,my 1997 has new pistons and rings..after 2750 miles,it still uses oil and has blowby.how much longer will this go on for???
Im thinking about loading up my Mercedes onto the car trailer and hauling it around....
You've got some hills in Kentucky right?
A loaded car trailer and a nice long 6% grade will do the job.
Only problem is you have to go downhill (no work) in order to go uphill again.
Got to put a load on her..I don't know if this affects a Cummins..But when dad was farming,he bought a new Massey tractor with a Perkins engine...He didn't worked the tractor hard enough and landed up glazing the cylinder walls..Had to overhaul the engine..
Blowby
Mototune moron: Do not follow this advice this guy is a IDIOT with a capital I.
Manufacturer break in procedures vary little, but if you "run it hard" to break in the rings, likely what will happen is the excessive heat friction from break in will overheat the rings and anneal them. This will take the spring tension out of the rings and they will BE RUINED IMMEDIATELY.
If the hone on the cylinders was inadequate to wear in the rings to match the bore, it may be hundreds of thousands of miles before the engine breaks in, since under most operating conditions with modern metallurgy (dissimilar materials-iron vs chrome moly rings) and modern petrochem engineering particularly zn oxide, the cylinders and rings simply do not wear appreciably.
Having said that, blowby is perfectly normal. It is impossible to create a reciprocating piston engine that is free of blowby, though full circle rings (overlapping step ends) cut it down a bit. Also the vacuum pump vents into the crank case, so it can be mistaken easily for blow by.
Oil use can also come from other places though. Bad valve seals for instance. Usually you don't use THAT much oil from valve seals though.
If you are using that much oil from the rings not being broken in, the problem is that the hone on the cylinders was not agressive enough, and it will take quite a good long time to fully break in.
Time to get it back to whoever did the work for a compression test.
On edit, this isn't the one that went down on you in Az. is it?
I need to drive the truck more.
I have a buddy who's Dodge uses a qt and then stops... every time.
I need to drive it more to see if this one is doing the same thing.
You did change out the Injectors, right?
