Brakes
Old Sep 16, 2007 | 09:54 PM
Brendan's Avatar
Brakes
My brakes have started acting funny. when used a couple of times in a row the peddle starts hardening up as if the engine is not running, like there is a vacuum issue. Any ideas???
Old Sep 16, 2007 | 10:13 PM
lgp9999's Avatar
Nothing off the top of my head, but I can assure you it's not vacuum related. On our trucks the power brakes are hydraulic and run off the power steering pump.
Old Sep 16, 2007 | 10:27 PM
logskidder's Avatar
Nope his 1994 uses vacuum.............check for leaks or a bad pump.
Old Sep 17, 2007 | 10:09 AM
infidel's Avatar
If you're having the problem only at idle the problem is normal.
The vacuum pump just can't keep up at low rpm.
Best fix is to be aware of it and throttle up.
The other fix is to add a vacuum storage tank, cheap and easy.
If the problem happens other than at idle you have a vacuum leak.
Old Sep 17, 2007 | 01:18 PM
lgp9999's Avatar
Oh wow! Thanks for the correction!
Old Sep 17, 2007 | 02:14 PM
logskidder's Avatar
Correct me if Im wrong.............there should be two vacuum tanks, one behind each headlamp...this is a good place to check because the tops of the tanks like to crack. IMO if the system is completely sealed and the pump is up to factory spec.....vacuum at low rpm should not be a problem.
Old Sep 17, 2007 | 06:34 PM
infidel's Avatar
This is the Dodge fix to correct the problem, $125, not covered by warranty, .
The vacuum tanks didn't come stock.
Old Sep 17, 2007 | 07:11 PM
Buckshotram's Avatar
My truck has been doing the exact same thing, I idled it up about 750-775 in when its in drive w ac on and it stops fine now but my parkbrake and abs lights on the dash still come on everynow and again but at least I can stop. Anybody tried to hook up one of those $35 vaccum tanks from jegs?? This seems like a pretty common problem.
Old Sep 18, 2007 | 09:56 AM
infidel's Avatar
I've installed homemade vacuum tanks on several trucks, hard part is finding a place to mount them.
Made the tanks out of a 12" length of PVC pipe with a cap glued on each end, 1/4" port drilled and tapped into into it. Barbed hose adaptor connects one hose to anywhere in the vacuum system. On a 2 wheel ABS truck there is room to mount this on the driver's side inner fender. On 4 wheel ABS about the only place is on the front of the radiator mount.
wildcargo
Nov 29, 2005 04:20 AM
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
