Brake Light Switch
Old Jul 24, 2007 | 04:57 PM
kronikpain's Avatar
Brake Light Switch
After reading a few threads about why my brake lights are staying on, I came to the conclusion that its the brake light switch behind the brake pedal. If I slightly lift the pedal with my foot the lights will turn off. So I just went and bought a new switch, even though I might be able to fix the existing one, I figured better to just get a new one. Seems like the old one is sticking.
So the question is, how do I get the old one out...Doesn't seem to just pop out easily, there are now instuctions with the new one. And it seems like I can easily mess up the wire harness, if I don't do it right. Theres not a lot of room down there...
Anybody thats done this before, please share with me what to do and not to do.
Thanks
Old Jul 24, 2007 | 05:01 PM
Box5's Avatar
I had that problem when I swapped pedals for my 5spd swap. The lights wouldn't go out unless u pulled up on the pedal slightly. So just layed a small tack weld where the pedal would hit the switch and that took care out it by filling the gap needed. I'll check the manual I have for the switch removal, because i'm not sure.
Old Jul 24, 2007 | 05:10 PM
clutch1's Avatar
there is an adjustmen on the switch if you didnt try it just pull the actuator all the way out and install there are detents in the switch to hold it in the right position. the switch comes out by pressing in on the sides of the switch.
kronikpain's Avatar
Hmmm, if I had a welder I'd do that. Now I'm thinking of what else I could use to fill the gap.
Old Jul 24, 2007 | 05:23 PM
kronikpain's Avatar
How is there any room up there to make any adjustments? Its hard to see whats going on.
Old Jul 24, 2007 | 06:55 PM
clutch1's Avatar
its not an adjustment, you just reach under there and pull the plunger all the way out then when you let the pedel go it sets the plunger where it needs to be, but you mentioned its hanging up so it might not help.
Old Jul 24, 2007 | 10:00 PM
fschiola's Avatar
Thanks
If you PM me an email address, I'll scan the page from my Haynes manual and send it to you.
Old Jul 25, 2007 | 12:50 AM
wcbcruzer's Avatar
Honostly, just adjust it to proper spec, then spray some brake parts cleaner in there and it'll probably be fine (disconnect battery). Then get a new one if you're still not satisfied.
Old Jul 25, 2007 | 01:41 PM
ekk33's Avatar
Check the bracket that the switch is attached to, mine was cracked,
Nothing the welder couldn't fix though
FordTrax
Sep 22, 2016 05:54 PM
Joey-D
Dec 12, 2011 12:52 PM
smokeyram
Aug 21, 2009 06:19 PM
polaris800sp
Apr 7, 2009 10:08 AM
redramnc
Mar 28, 2005 06:58 AM
