Brake help
Old Aug 7, 2006 | 01:10 PM
Jambbii's Avatar
Brake help
My brakes lose vacuum over long stops ( freeway off ramps etc) and repeated use. When I bought the truck I first noticed this 4 wheeling when I was on a slow decent and so on. I made a vacume canister with a check valve. Helped a little bit. I also have the upgraded gm rear cylinders. My truck is also lifted and I know this puts extra strain on the system but they seem to always lose vacuum. I have learned to live with this for a while but I more worried about when the girlfriend needs to drive the truck or someone else. I usually dont have a problem stopping the truck thanks to doing squats at the gym
I could my vacuum booster be deteriorated? Can think of what else besides my vacuum pump could be bad but everything else works fine.
Thanks,
Josh
Old Aug 7, 2006 | 09:54 PM
infidel's Avatar
The check valve on your vacuum canister will either make it not let in vacuum or let it out.
No check valve is needed and could be your only problem
Old Aug 8, 2006 | 02:41 PM
Jambbii's Avatar
I just added the check valve to help aid my problem, did not do much. The reason I did it is because I read on alldatapro.com about the TSB with dodge adding a check valve to the vacuum pump to stop oil from getting into the lines.
Old Aug 8, 2006 | 07:24 PM
infidel's Avatar
The check valve in the TSB is right at the outlet of the vacuum pump.
Your rig should be covered for it on recall
Old Aug 9, 2006 | 01:12 PM
Jambbii's Avatar
I figured it would have been too late. Do I just go talk to a dealer or what?
Thanks
Old Aug 9, 2006 | 06:42 PM
infidel's Avatar
Thanks
Recalls are free for the life of the vehicle no matter how old or how many different owners.
Try running your VIN though this first
http://www.dodge.com/webselfservice/...m('R')
Here's the recall itself http://dodgeram.info/tsb/recalls/720.htm
Old Aug 10, 2006 | 02:02 AM
Jambbii's Avatar
Thanks for the info!!!
dieselluvr
Dec 29, 2013 11:02 PM
mr T
Oct 16, 2005 07:38 PM
ddestruel
Apr 6, 2005 11:26 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
