borescope/kdp
Old Dec 7, 2009 | 07:41 AM
Hodge's Avatar
borescope/kdp
Does anyone know if, on a 12 valve, you can use a borescope to see if the pin has moved? I read on here on another post that you could through the hole where the IP goes, but how about the oil fill neck? It sure would be nice to take a peek before tearing things down.
Old Dec 7, 2009 | 08:20 AM
roughstock's Avatar
I dont believe so. Too many gears in the way.
Old Dec 7, 2009 | 10:02 AM
infidel's Avatar
Over the years many people have tried with no success, too much in the way.
You probably could make it work by drilling a hole in the front cover right on top of the pin then plugging the hole with RTV and a self tapping screw after you're done.
Old Dec 8, 2009 | 08:05 PM
roughstock's Avatar
If u are not sure about your KDP go ahead and tear it down and check.
Mine fell out at 280k I thought it was fine. Cost $ and time. I even had the kit months before.
Old Dec 9, 2009 | 03:23 PM
Hodge's Avatar
If I can't check it any other way, then I will. But, if it is still in place, and I could check it periodically, then why tear everything apart?
6spd05Dually
Feb 12, 2013 07:05 PM
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
