Boost Sensor line hook up for P-7100 question.....
Old Mar 4, 2005 | 02:48 PM
Diesel-Dan's Avatar
Howdy all! Just wondering if any have had this issue. i have a buddy that i am tring to help out. he has a 1996 3500 12V Dodge. I was doing a T-plate and 3K springs and noted that the boost sensor line bung going into the AFC Housing was VERY loose. I would almost assume that boost had to be leaking the way the truck drove afterwards......no smoke at all! It seemed to be some sort of a press fit. WELP....i have never been into this part of the pump. It seems to be some sort of a diaphram with 4 bolts holding the cover on with the boost bung sticking out of the housing. Is there a cheap fix for this or we looking to find a new houseing for the AFC Diaphram cover? I was thinking about pulling it and removing the piece and tring to tap a new NPT fitting into it. Think this would work? Let me know what yall think! Thanks!
Dan
Old Mar 4, 2005 | 05:29 PM
P.O.R.'s Avatar
that part of the afc is where you would change the afc spring if you where putting a afc spring kit in a 12 valve,if it is threaded in i would think you could use tape or paste to seal it up,if it is pressed in maybe some jb weld or something similar...
Old Mar 5, 2005 | 10:00 PM
got...DIESEL?'s Avatar
it IS threaded, and it IS a pipe thread. If it's loose and another 1/2 turn or a little more won't snug her up, try a little teflon tape. As a last result, the housing can be drilled (once apart) and tapped the next size up. Then a reducing bushin can be used to make up the size difference. This pressure tap is open on the underside to a diaphram chamber.
Chris
xtrm4xjp
Jun 19, 2005 01:11 PM
FITZER1
Apr 7, 2005 08:55 AM
jughead
Jan 15, 2005 06:51 PM
whiteknight
Dec 27, 2002 08:08 PM
