boost elbow
boost elbow
ive seen that in the tst kit it comes with the plate and boost elbow. my question is how does it accutaly increase your boost? the fitting looks like something i can get from the parts store. and grind my own plate=more hp.???
The boost elbow that comes with the kit has a smaller orifice in it so it raises the max boost. If you already have a fuel plate on your truck you can add an adjustable boost elbow to raise boost if needed.
If you aren't adding so much fuel or you can control your foot to prevent overboost you can often get by with just blocking the line to the wastegate rather than using an elbow.
A 1/4" bolt or a .22 shell with a hose clamp to plug the line works excellent as long as you aren't exceeding 35psi boost often.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
