bluish smoke
Old Nov 19, 2009 | 10:46 PM
Schneider's Avatar
bluish smoke
so my truck is smoking bluish white smoke. im not sure if it is bad injectors or something else. It will smoke at idle then i will drive it and it will stop smoking but when i park it it will start to smoke again after a little while. Just wondering if anybody had an idea? Thanks.
Old Nov 20, 2009 | 11:01 AM
BigErksG2's Avatar
Blue usually means oil is burning. Could be valve seals, leaking turbo, or worn rings. How many miles you have on that thing? Check your blowby tube at idle, it should have a small flow of air but not screaming out of it, while youre down there see if you are puking oil from the tube. Residue is normal on the underside of the truck.
Old Nov 20, 2009 | 03:38 PM
Schneider's Avatar
ok i lill check but it sill have to be later cuase i have to go to work... but it has 242000 miles on it.
Old Nov 20, 2009 | 03:40 PM
Schneider's Avatar
it does leak oil a little bit like a half dollar size every night so it might be coming from that tube.
Old Nov 20, 2009 | 05:09 PM
Lil Dog's Avatar
Have you adjusted timing? Some late timing will cause the bluish smoke you are observing. This is due to incomplete burn of the fuel and with the symptom of it coming back after it idles, that would be my guess. Also the overflow valve may be weak allowing lower fuel pressure in the pump, which will do the same thing and retard timing.
Old Nov 20, 2009 | 09:57 PM
Schneider's Avatar
Im not sure if the timing is changed cause i just got the truck a couple of months ago... and could i change the overflow valve of what is that... and im not sure how to do timing i was going to have sombody do that for me i heard it was complicated.
Old Nov 20, 2009 | 11:03 PM
torquefan's Avatar
Ditto on the timing.
Old Nov 23, 2009 | 11:35 AM
Lil Dog's Avatar
Timing isn't a shadetree job for sure. You need specialty tools and know what you are doing to have it done properly. I just say that because its something that slowly wears away over time and makes a big difference.
Here is some information on the Overflow valve and testing..
Dodgeram.org-overflow
ridofpwrstroke
Aug 2, 2012 12:26 AM
Common
Feb 28, 2009 11:05 AM
Common
29
Mar 19, 2007 11:54 AM
berner
Jul 15, 2003 01:27 PM
97CTD
Mar 17, 2003 08:14 PM
