Block Swapping
Old Feb 6, 2005 | 09:43 AM
pvkj454's Avatar
Block Swapping
I have a 1994 12 valve engine from a burned UPS truck that has some heavy pitting in 2 cylinders that won't hone out, the other 4 still have the crosshatches. I also have access to a 1990 block that had a broken camshaft. Will the blocks interchange, or would I be better off to have the block bored. How expensive are oversize pistons?
Thanks.
Old Feb 6, 2005 | 12:27 PM
John Faughn's Avatar
You mignt try to find a machine shop that works on trucks and ask if they could sleve your block , this makes it like the semi truck eng. were they can do an inframe rebuld by pulling the sleves -now removable cylinders- insted of honeing or boreing the block , they used to do it to CAT. 3208 s , before that they called em throughaway engines.
Old Feb 6, 2005 | 02:12 PM
Haulin_in_Dixie's Avatar
Oversized pistons are not that expensive from Cummins. Or the better way is to bore it sleeve it and bore it to stock. Never heard of a wet sleeve conversion on the B engine, would be too expensive anyway.
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
