Best engine oil
Old Aug 21, 2007 | 07:44 PM
kelownadiesel's Avatar
I think he means the oil type man,if hes got 600k on the thing he obviously changes his oil regularly
Old Aug 22, 2007 | 12:12 AM
TexasCTD's Avatar
Originally Posted by wcbcruzer
Is Premium Blue a CI-4+ oil?
I just looked up their website....http://www.valvoline.com/premiumblue/ and the regular PB is CJ Blend. The PB Extreme is still CI-4+.
Same with Rotella and Rotella Synthetic. Reg. Rotella is CJ and the Rotella Synthetic is CI-4+.
Old Aug 22, 2007 | 09:02 PM
RenegadeT's Avatar
Hmmm, crap. I just bought a case of Rotella T 15W40 Triple Protection gallons, its CJ-4. I also have one of the old Rotella T15W40 gallons (no Triple Protection badge), its shown as CI-4 PLUS. I wonder if this is the same stuff, or did Shell have to change the formulation to meet CJ-4 requirements? Are all the manufacturers going to CJ-4...what is CJ-4? off to the internet...
Old Aug 22, 2007 | 09:12 PM
wcbcruzer's Avatar
It's not the same stuff. Honostly, I wouln't hesitate to use the new Rotella. I bought a couple gallons too.
Old Aug 22, 2007 | 09:13 PM
wreedCTD's Avatar
If Cummins and none of the other big diesel manufactures are worrying about the new oil I am not going to either.
Old Aug 22, 2007 | 09:19 PM
RenegadeT's Avatar
Originally Posted by TexasCTD
I just looked up their website....http://www.valvoline.com/premiumblue/ and the regular PB is CJ Blend....
The test used a Valvoline PB rated at CI-4PLUS, but the current PB is CJ-4...are the test results still valid?
Old Aug 22, 2007 | 09:41 PM
bry@n's Avatar
My local Cummins dealer still has the older CI+ 15w40 oil. They had 200+ gallons in stock.
Old Aug 23, 2007 | 12:19 AM
99globalwarmer's Avatar
Wink
amsoil is what i run with the double bypass and i love the oil hels with milage also.
Old Aug 23, 2007 | 01:23 AM
DennisT's Avatar
oil
Good thread, if alarming. I just bought two gallons of Chev. Delo 400 15-40.....LE. Grange Supply here said that is all they can get now in Delo 400. So should I scrap the LE?
This is getting disgusting.
Dennis
Old Aug 23, 2007 | 07:00 AM
bry@n's Avatar
I just started stocking up oil. I usually have enough for 2 oil changes sitting around but after this article, I've been stock piling. Maybe then the CJ-4 oil will be better.
At some point though, CJ-4 will be all we can get so....
Old Aug 23, 2007 | 09:49 AM
infidel's Avatar
I agree almost 100% but some of the off road engine manufacturers such as John Deere are recommending if you use off road low sulfur diesel (LSD)instead of on road ultra low sulfur diesel (ULSD) that you should stick to CI oil.
Think as time passes all the concern about CJ oil will be unfounded.
ClassA4x4
May 16, 2013 11:49 AM
Walt L
Nov 4, 2010 11:02 PM
rufushusky
May 10, 2009 12:41 PM
realoldandcrust
Feb 14, 2008 09:53 AM
rico334
Jan 3, 2005 08:10 AM
