Auto Trans cold weather performance
Old Mar 30, 2006 | 11:25 AM
glockrow's Avatar
On a cold morning the auto tranny on my 1995 3/4 ton will sometimes take 3 or 4 miles at 50-60 mph before it will shift into high gear. Just wondering if this is normal or should I be worried?
Old Mar 30, 2006 | 01:53 PM
JKM's Avatar
JKM
Completely normal , the trans has to get warmed up before the PCM will allow O/D , or lockup , you can unplug the sender in the tranny line and jump it with a 1000 ohm resitor , which tells the PCM that the tranny is at 100 deg. Infidel assures me this will not hurt the tranny at all.
Old Mar 30, 2006 | 07:25 PM
infidel's Avatar
It won't hurt it in the cold but if you jump the sensor with a resistor your overheating idiot light won't work either. Don't jump across the sensor wires unless you have a trans temp gauge.
Grit Dog
Nov 19, 2008 07:12 PM
Grit Dog
Nov 19, 2008 08:14 AM
HOHN
Oct 26, 2005 08:36 AM
wings
Nov 8, 2004 05:32 PM
JORDAN
Jan 13, 2003 09:34 PM
