New flash for cold weather performance?!!
Old Jan 13, 2003 | 09:09 PM
JORDAN's Avatar
hey i was looking up the tsb for the high idle when i came upon the tsb[url=http://www.dodgeram.info/tsb/2001/18-014-01.htm) the tsb # is 18-014-01 it says that it applies to all ram trucks with 24 valve cummins and auto. anybody know what this will do (or mess up)??
Old Jan 13, 2003 | 09:14 PM
phox_mulder's Avatar
Re:New flash for cold weather performance?!!
There's been a bit of discussion of this here and other boards.<br><br>Here's a link to one of them here<br><br>https://www.dieseltruckresource.com/...;threadid=8463<br><br>Consensus seems to be it works sometimes and doesn't sometimes.<br>Main problem seems to be the techs can't get the &quot;enable&quot; to stick in the PCM.<br>Basically the PCM has to be updated with the new program (in 2001 and older) then has to be enabled with another step.<br><br>good luck<br><br>phox
Old Jan 13, 2003 | 09:20 PM
JORDAN's Avatar
sorry i should have been more exact the flash they are talking about is for the high idle feature tsb#18-019-01 this was only for auto's tsb #18-014-01 what i am wondering is will this also enable the high idle feature?
Old Jan 13, 2003 | 09:34 PM
Sorry here too.
Saw &quot;High Idle&quot; and had flashbacks.
That reflash doesn't look like it will do anything for high idle.
Large print says:
NOTE: THIS CHANGE WILL HAVE NO EFFECT ON PERFORMANCE DURING WARM WEATHER OR WHEN STANDARD GRADE DIESEL FUELS #1 OR #2 ARE USED. (referring to sub-grade #1 diesel fuel)
I doubt if &quot;sub-grade #1&quot; diesel is used anywhere below Canada, if even that far south.
I read that to be below #1 Deisel, like straight kerosene or something.
phox
8mpg
Apr 28, 2006 10:08 AM
glockrow
Mar 30, 2006 07:25 PM
HOHN
Oct 26, 2005 08:36 AM
joel
Jan 22, 2005 08:59 PM
wings
Nov 8, 2004 05:32 PM
