Anybody near Cleveland, OH? & Can help me out?
Old Jan 19, 2004 | 11:03 AM
psdctd's Avatar
Question Anybody near Cleveland, OH? & Can help me out?
I'm getting very frustrated trying to find a good "Cummins Guy" in NE Ohio to help me figure out why my truck is such a dog!
Any of you guys know somebody or can recommend a good place?
I gotta find somebody soon.......or else this truck's gotta go!
Old Jan 19, 2004 | 10:41 PM
SmokinDodge12V's Avatar
Dont give up you will find someone and you also have one of the hardest trucks to find, have you checked with Enterprise Engines there not NE but they are in Ohio and they do know there stuff. Good Luck
Old Jan 20, 2004 | 03:45 PM
dodgediesel98's Avatar
hey I live in Mentor. I don't really know of any shops because i mostly do the work myself. What is wrong with your truck and maybe i can help?
Old Jan 21, 2004 | 07:49 AM
psdctd's Avatar
I would just say it's a D-O-G! I've only had it for 3 months and my diesel experience prior to this truck was all Powerstroke. And my 96 Powerstroke will run circles around this thing! I have a 3 place snowmobile trailer, weighs about 4000lbs loaded, and this truck struggles to maintain 60 mph on any kind of grade. If I have to get out of the throttle for some reason, forget it!...I lose all momentum and it takes forever to get back up to 60 - 65...
It just doesn't have any ooomph! And the mileage on the highway is 14 mpg tops! I changed the fuel filter, put on a 4" exhaust so far....
I'd really appreciate any advice or help you could lend...and be willing to bring it up to have you take a look at it and tell me what it needs! From what I read here, I should have some serious pulling power!
Thanks
Todd
Old Jan 21, 2004 | 10:30 AM
dodgeman01's Avatar
sounds like a retimm of the engine and a plate would fix the problem. also check the lift pump and over flow valve just to see.
DM01
Old Jan 21, 2004 | 01:29 PM
BIG&BAD's Avatar
why dont your slid you stock plate forward?
i dont know how much power you'll get but it should help alittle
or just grind it flat and get a boost elbow
Old Jan 21, 2004 | 02:54 PM
Rhino's Avatar
I think first it is important to figure out what is wrong with the truck before sliding the stock plate or adding an aftermarket plate.
A few suggestions I would have are to check you fuel pressure and check for boost leaks. The truck should pull 4k lbs at 60 MPH without too much effort. It could be your timing is a bit off but if you are that low on power I would look elsewhere first.
Best of luck.
Old Jan 21, 2004 | 05:29 PM
psdctd's Avatar
Anyway to find boost leaks without a gauge?
And I need help checking the fuel pressure!
DanTana
Jan 28, 2007 05:56 PM
Lightman
13
Aug 16, 2005 08:49 AM
CRF_Diesel
15
Apr 21, 2005 09:00 AM
ROTTBERGZ
Jan 30, 2005 03:56 PM
