98 12v KDP ?
Old Jul 7, 2006 | 05:56 PM
whtractor's Avatar
98 12v KDP ?
Do I need to tab the KDP on my 98 12v? I have heard that this was fixed from the factory or is this fales.
Old Jul 7, 2006 | 06:17 PM
Dr. Evil's Avatar
The KDP was absolutely NOT fixed at the factory - whoever told you that was misinformed. You must pull the cover and tab the pin before you have an $$$ repair.
I cant find the link of the KDP carnage...does anyone have it?
Old Jul 7, 2006 | 06:19 PM
9812v's Avatar
As far as I know the factory did not fix them. I tabbed my 98 12 valve as soon as I heard of the problem. Mine was working it's way out of there but not too far, I am glad I did it.
Old Jul 7, 2006 | 06:25 PM
TxDiesel007's Avatar
The Dr is correct..
Its never too soon to tab it.... i killed mine at 165K... lucky me tho it was still deep in the case...
Rick
Old Jul 7, 2006 | 06:41 PM
Dr. Evil's Avatar
Mine was working loose too - truck has less than 100k (98 12V).
Old Jul 7, 2006 | 07:22 PM
bmoeller's Avatar
Some of the early 24v engines had the same problem, 'til the they came out with an updated case with a stepped hole to prevent the problem.
Why they just didn't make it a blind hole in the first place is beyond me.
Old Jul 10, 2006 | 06:23 PM
whtractor's Avatar
thanks for info, iam going to get this done asap.
Old Jul 10, 2006 | 06:35 PM
satburn's Avatar
http://www.cumminsdatabase.com/read.php?id=111
Old Jul 10, 2006 | 07:33 PM
Dr. Evil's Avatar
Originally Posted by satburn
Thats the one I was thinking about - maximum carnage !
whtractor, this is also a very good time to bump your timing (up to ~16 degrees) since you will already have the timing cover off.
Old Jul 10, 2006 | 07:43 PM
big jimmy's Avatar
Thats where I got my blocking tab specs from- it took me like 5 minutes to fab it and tally ho...
Old Jul 11, 2006 | 12:02 AM
Kminnick's Avatar
Sounds straight forward... But is there a link to advancing the timing while I'm in there? Thanks, Kelly
Old Jul 11, 2006 | 08:24 AM
JimmieD's Avatar
What K said, link...?
Old Jul 11, 2006 | 09:41 AM
infidel's Avatar
http://dodgeram.info/tsb/1994/18-10-94a.htm
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
RaiderRedRam
Feb 21, 2009 08:46 PM
FANZDSLPWR
17
Jun 23, 2004 06:05 PM
Encryptic
Jun 23, 2004 08:58 AM
