12v Kdp
Old Jun 15, 2004 | 06:17 AM
FANZDSLPWR's Avatar
12v Kdp
I bought my 96 12 v in February with 96000 miles . How can i tell if the kdp was fixed or not?
Old Jun 15, 2004 | 06:57 AM
MDW's Avatar
MDW
Take the front cover off and look.
Old Jun 15, 2004 | 01:13 PM
FANZDSLPWR's Avatar
Front cover of what?
Old Jun 15, 2004 | 01:29 PM
earl78621's Avatar
the front cover of the engine!
Old Jun 15, 2004 | 02:41 PM
INJECTOR JACK's Avatar
kdp
You have to look at the front cover were the timing gears are to if it has been tabbed.
Old Jun 15, 2004 | 03:54 PM
kd460's Avatar
Yep, no other way to know for sure unless it was pinned. That you can see from the outside. The timing gear cover has to come off. Do a search on KDP, Dowel Pin, etc. You will find tons of info. Search on google also. I ran accross a website with some pics once.
Not that big of a deal to do. Just takes time and about $50.00 worth of parts. The tab can be home made. You will find specs when you do a search. The crank seal is the hardest part. If you put it in backwards while the cover is off, it seems easier.
One thing for sure is to get it fixed. Also re-tourque any of the bolts behind the cover while you have it off. I have heard of one guy having a bolt come out into the gears after he had the pin tabbed. Bummer! It is such a cheap and fairly easy thing to do and the damage is expensive!!!! Good Luck, Kevin
Old Jun 15, 2004 | 03:56 PM
Smokee's Avatar
Here you go, FanZ
https://www.dieseltruckresource.com/...p;highlight=kdp
Old Jun 16, 2004 | 08:15 AM
FANZDSLPWR's Avatar
thanks for your time guys . so in other words i have to remove the radiater in order to see the case?
Old Jun 16, 2004 | 09:42 AM
infidel's Avatar
No need to remove the radiator Follow the instructions like you were going to do the tab fix. It's the only way to tell if it's been done unless you wait for the pin to come out and cream your engine. Have a tab on hand in case you need it.
If you can find the previous owner of the truck they might know if it's been done. You can pretty much assume it hasn't been done unless the pin has come out previously and gear case was replaced by one that won't let the pin escape.
Tab instructions here- http://dodgeram.org/tech/dsl/Dowel_Pin/tab.htm
Old Jun 16, 2004 | 02:59 PM
FANZDSLPWR's Avatar
thankyou for the information.
Old Jun 18, 2004 | 09:50 PM
I see you are in NJ, I'm in the Philly suburbs. PM me if you'd like me to deal with Mr. KDP.
Old Jun 18, 2004 | 10:00 PM
dieselcrazy's Avatar
wannadiesel has a hair trigger when it comes to those pesky kdp problems. trust me i know. hey dave shouldnt it be gottadiesel now ?? :-) scott
Old Jun 18, 2004 | 10:11 PM
I only pestered you a little to get you over here, Scott.
Yeah, should be but it's too late now. I knew I should've tried harder to come up with a cool handle when I registered...
Old Jun 21, 2004 | 07:05 PM
dave, didnt mean to imply that you pestered me. i should have thought my wording out a little more. i meant it in the way that you like to kill that nasty little devil and pretty darn quickly to considering it is one of the coldest days of the year when you did mine. thanks again buddy
Old Jun 21, 2004 | 07:21 PM
Gotta work faster when you're freezing to death. I was never happier to work on a warm engine than that day. Hey, yours isn't leaking any oil around the setscrew is it?
