95 Will not start
Old May 10, 2010 | 03:21 PM
badzj999's Avatar
95 Will not start
This problem has seemed to come and go a few times the past week or so but now it will not start at all. Both my batteries have full power and all the connections seem to be tight and clean. When I go to turn the key in the ignition nothing happens at all. Not even a noise from the solenoid. I took out the starter and bench tested it and the solenoid engaged fine so I reinstalled the starter and the truck started right up. Then after i turned the engine off it will not start again and there is no sign of power getting to the starter when i turn the key. It may be the staer relay, where is this located?
Old May 10, 2010 | 04:24 PM
patdaly's Avatar
PDC ( Power Distribution Center ) located on the drivers inner fenderwell, take the cover off and it will be labeled.
Could also be corrosion under relay.....
Old May 13, 2010 | 06:14 AM
badzj999's Avatar
well it was not the relay so I rebuilt the starter.... that did not get the truck started either. Luckily they forgot to quote me on the rebuild so they only charged me $40 to rebuild it! I have run out of possible problems in the system. The starter is getting power, the batteries are ok, the relay is new, the starter is now rebuilt and the connections are clean and tight..... what could i be missing? could it be at the ignition? remember when i turn the key NOTHING happens. you do not hear a sound of anything clicking or engaging so somewhere in the system something is wrong even though power is getting to the starter.
Old May 13, 2010 | 08:01 AM
ET RAM's Avatar
You need to check for power at the solenoid terminal. This will require a helper and a volt meter. Have the helper try to start the engine. At the same time you check for voltage at the solenoid terminal. You should read battery voltage when the igintion switch is held to start. Check the battery voltage first to have that reading as reference.
Do this with care as the engine may turn over or start.
It could be a bad ignition switch or a safety switch. The manual tranny has a clutch switch and the automatic has neutral start switch. If the safety switch is not made you get no power to the solenoid.
If it is automatic, move the shifter thru all the gears then try to start in park and neutral.
I will check tonight to see if I have the starting circuit schematic. If yes I can email it to you. 1995 and what model truck?
Old May 13, 2010 | 08:52 AM
badzj999's Avatar
95 4x4 auto
Old May 13, 2010 | 09:21 AM
infidel's Avatar
Swap the ASD relay in the underhood fuse box with the A/C relay.
If that doesn't get it could be the key switch.
About $30 for a new one at Napa.
Old May 13, 2010 | 10:19 AM
badzj999's Avatar
how do i go about replacing the key switch?
Old May 13, 2010 | 06:25 PM
infidel's Avatar
Click> http://dodgeram.org/tech/repair/elect/ign_switch.htm
Old May 14, 2010 | 07:26 AM
badzj999's Avatar
Old Jun 3, 2010 | 10:59 AM
badzj999's Avatar
It was the neutral safety switch... replaced it and now it starts.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
loosendend
Sep 4, 2006 12:01 PM
