92 12 valve removing a/c?
Old Mar 17, 2015 | 06:44 PM
blueghost08's Avatar
Im taking my a/c pump off my 92 12 valve motor so i tried doing some research n some pics show a smooth belt tensioner pulley can you get away with that? If you guys have the part number for the grooved pulley id like to go that route or any other info is appreciated
Old Mar 17, 2015 | 07:18 PM
Busboy's Avatar
A smooth pulley is used on the back side of the belt but if you look up the belt routing for a NON AC truck then get a NON AC belt you might find that no other parts are required. I used to carry a non AC belt as a spare for my 2001, never know when that compressor would bite the dust.
Old Mar 17, 2015 | 08:37 PM
I didnt know if they make a ribbed pulley I was looking at it and doesnt seem like enough clearance between the belt the the aluminum part of the tensioner though
Old Mar 18, 2015 | 08:11 AM
patdaly's Avatar
I don't believe anyone makes a ribbed pulley, doesn't seem to matter to the belt.
Here is the routing chart for both AC and non.
92 12 valve removing a/c?-cummins-belt-routing.jpg
Old Mar 18, 2015 | 06:45 PM
Ok i was just curious thank you
Old Mar 19, 2015 | 02:32 PM
Busboy's Avatar
Ah you may be right Pat, I'm probably thinking back to the "V" belt days of a smooth idler and a "V" idler pulley.
Old Mar 19, 2015 | 05:27 PM
patdaly's Avatar
No, I have seen various serp. ribbed idler pulleys over the years, I just can't find one for the Cummins........
smokinram99
Jul 20, 2008 06:07 PM
hamilton71801
Jan 9, 2007 12:27 PM
xtremexj
Aug 14, 2006 09:42 AM
Austin'sDodge
Jan 28, 2006 03:33 PM
badmrb
Nov 28, 2005 11:02 AM
