500 H.P.
Old Nov 5, 2002 | 07:16 PM
1ST GEN.'s Avatar
500 H.P.
I PLAN ON PUTTING A PDR HX 40 TURBO, A SET OF 370 INJECTORS, 191 DELIVERY VAVLES, A # 10 PLATE SLID FOWARD AND WITH A FULLY TURNED IN AFC WHEEL WILL I GET 500 H.P AND WILL EGTS BE OUT OF CONTROL
Old Nov 5, 2002 | 07:20 PM
cummins24's Avatar
Re:500 H.P.
Yes your egts are going to get up there fast. The delivery valves are bad about egts and the 370's wont help either. You have to get more air into the motor. Put in a cam that will help, but that set up is EGT sensative.
Old Nov 5, 2002 | 08:09 PM
Don M's Avatar
DTR Advertiser
Re:500 H.P.
What pump do you have? You can get close with a small pump but it is tough.<br><br>Don~
Old Nov 5, 2002 | 09:47 PM
1ST GEN.'s Avatar
Re:500 H.P.
I HAVE THE 215 HP PUMP
Old Nov 5, 2002 | 11:53 PM
Lil Dog's Avatar
Re:500 H.P.
You'll probably be good for about 400 RWHP for sure.. EGT's will be a function of your pump calibration and timing as well.<br><br>I have my doubts about 500... <br><br>J-eh
Old Nov 6, 2002 | 09:30 AM
Michael  Az's Avatar
Re:500 H.P.
I dynoed 403 with the stock turbo. EGT's were pretty fast and hot.<br>Michael
Old Nov 6, 2002 | 03:25 PM
1ST GEN.'s Avatar
Re:500 H.P.
HOW MUCH WILL A MARINE CAM LOWER EGT 'S AND IS THAT THE BEST CAM TO GO WILL OR ARE THERE OTHER CAMS THAT ARE BETTER AND ABOUT HOW MUCH DO THEY COST
Old Nov 6, 2002 | 06:20 PM
Michael  Az's Avatar
Re:500 H.P.
I would call Piers about a cam. Piers Diesel Research. They have a web site.<br>Michael
Old Nov 6, 2002 | 08:37 PM
Sled Puller's Avatar
Re:500 H.P.
www.enterpriseengine.com prolly has done more with cams for longer than anyone else at this point.<br>I don't think a cam is agood investment of BOMB money at your point.
Old Nov 6, 2002 | 08:47 PM
J.R. Adkins's Avatar
Re:500 H.P.
Gene,<br><br> Witch way would you go next? Port, polish and flow or.......?<br><br><br>J.R.
Old Nov 6, 2002 | 10:07 PM
Re:500 H.P.
I wouldn't take the head off JUST to port it, if it was off for another reason, yea, sure, clean it up, but don't take too much, it will weaken it.<br>I would work on getting large volumes of cool air to the turbo,at that point. Bump the timing to 16.<br><br>With that set up, the only palce he would dyno 500, is Vegas, or Texas.
Old Nov 7, 2002 | 12:18 AM
yomitch's Avatar
Re:500 H.P.
I've been working the last couple of days in a heavy duty diesel repair shop and the owner who has been a western canadian cummins dealer for years told me of an upgrade to 700hp. he'd have to tell you the details himself but... because I'm doing him a favour by wiring a genset for him he is upgrading my 95 dually by installing a new tubo housing and if you can help me with this he told me that he will be installing a &quot;cam plate&quot; in the injector pump. What does that do? I have basic knowledge of how these bosch pumps work but can you help me out?
Old Nov 7, 2002 | 09:16 AM
MDKram's Avatar
Re:500 H.P.
yomitch, make sure you install gauges before you put in the cam plate. If the owner of the shop tells you that gauges are not required, smile, thank him for his time and go see Noel at Newport Auto in Squamish. <br><br>The cam plate establishes the fuel rack position at full load. Aftermarket cam plates allow the rack to travel further thus increase the volume of fuel delivered to each injector.<br>Marc
Hummin Cummins
Feb 11, 2003 12:14 PM
figure_9_pro
Nov 30, 2002 06:18 AM
d-hlaw
Nov 26, 2002 01:29 PM
