47re Problem...A big one
Old Feb 18, 2007 | 03:55 PM
kevellis32's Avatar
Originally Posted by badme
Sounds to me like a ground problem maybe. You said it is not shifting also, this could all be related. Check the grounds first.
How do i check the grounds?
Old Feb 18, 2007 | 07:07 PM
badme's Avatar
Well... if you have a good volt meter you could check voltage drop, otherwise start at the battery and clean both terminals, then clean the ground at the block, then move on to the ones on the inner fender. If you can find a ground clean it, use a wire brush. If you want to do a voltage drop test this link explains it pretty good
http://www.aa1car.com/library/voltage_drop_testing.htm
Old Mar 19, 2007 | 09:04 AM
chadpatten's Avatar
Kev,
Did you find you problem? I am having some trans probs like yours also and need help. My wife goes to CSU and we are new to Fort Collins. Maybe you could help me.
Chad Patten
thehemikid
Feb 25, 2021 12:45 PM
deaconn
Jun 17, 2007 01:55 AM
Munchies
Oct 19, 2006 06:09 AM
Valv
Mar 24, 2005 06:55 PM
Shaders 24v
Aug 11, 2003 10:18 AM
