47re Problem...A big one
Old Feb 10, 2007 | 09:57 PM
kevellis32's Avatar
I still cannot figure out what happened to my tranny. I was driving down the road, minding my own business and all of a sudden my transmission just shift and locked into gear, when I slowed it would not release out of gear and nearly stalled the truck till i shifted back into 2nd gear. It only happens when I put it in drive, the transmission will shift and lock into gear and not come out unless i put it in second gear. Every now and then It won't even shift into drive, but I am absolutly clueless...Any one else have this happen to them? I am short on cash so please don't say, call ATS, DTT, or Goerend Bros. Yes they are great, but i don't have 5k to spend.
Old Feb 10, 2007 | 10:06 PM
mainer's Avatar
sounds like something with lockup solenoid.... its not unlocking in 3rd and 4th gear....
Old Feb 10, 2007 | 11:47 PM
ckt_santiago's Avatar
Sounds to me like your lock-up solenoid is acting up on the PCM side of things.... Gotta figure out which one it is underneath but you can hot wire your solenoid by taking it to ground by toggle. My PCM has been burnt out for about 7 months now and I've been running toggles on my lock-up and OD ever since. If I do put a PCM in it I am sticking with manually flippin the switches because the shift points that are programmed into the PCM suck ****. If you want to hot wire it completely PM me and I'll tell you what wires to take to ground and you'll be all set. If you don't like that idea I would look into getting another PCM.
Old Feb 10, 2007 | 11:53 PM
Need95-00CTD's Avatar
The above sounds right, if your PCM is the problem if you put power to pin 54 it will make the lockup solenoid stay unlocked, it may just be a simple short somewhere, but good luck finding it. I would follow the directions from this link, but instead of connecting it to a ground, connect it to a power source, and put a switch on it. heres the link:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Feb 11, 2007 | 11:01 AM
CmminsBeast's Avatar
I had this problem. It was a solenoid inside the tranny. I can't remember the exact name. A friend put a new one in. It was about a $85.00 part from dodge (wholesale).
Old Feb 11, 2007 | 12:29 PM
kevellis32's Avatar
What did you have to do to replace the solenoid. I have easy access to a lift and qualified tech's, is it an easy fix? Just remove the tranny pan or what? thanks alot guys...
Old Feb 11, 2007 | 12:30 PM
kevellis32's Avatar
And also, I was driving this morning, and now it will hardly shift out of 1st gear, so i had to take side streets home at about 15mph, man was that a blast
Old Feb 11, 2007 | 04:33 PM
Yep, take off tranny pan. I believe there is 2, I don't remember which one it was he replaced.
Old Feb 11, 2007 | 10:43 PM
smknram's Avatar
yes there are 2. drop the pan and filter and they are right there on the valve body. i dont know off hand which one is which but i would probably just replace both, on cost 80 couple dollars and the other is 90 couple dollars
Old Feb 16, 2007 | 08:41 PM
kevellis32's Avatar
anyone have any clue what those two solenoids are called?
Old Feb 17, 2007 | 07:15 PM
wilderness's Avatar
Torque converter lock up solenoids. I had the same problem with mine, it got so bad I'd have to put it in neutral at stop lights.
Old Feb 17, 2007 | 08:36 PM
badme's Avatar
One is the torque converter solenoid and the other is for the 3/4 shift
Old Feb 17, 2007 | 08:38 PM
badme's Avatar
Sounds to me like a ground problem maybe. You said it is not shifting also, this could all be related. Check the grounds first.
Old Feb 17, 2007 | 08:50 PM
95% sure it will be the T/Q solenoid....
Old Feb 17, 2007 | 09:54 PM
2500's Avatar
before you replace solenoids, test them. simply unhook, then apply 12v. they should click every time. problems may be bad connections.
