47re help no O/ or auto shifting
just installed a remaned trans in a 97 12v the truck will not shift on its own. if you drop the shifter into drive it starts off in drive. if you manually shift it it shifts fine. also o/d will not engage. the same problems that killed the last trans. where to look next. all gauges work fine and the o/d light works Rob
tested out fine. took it to aamco and they put a scan tool on it and a lot of codes they reset the code took for a ride and everytime the trans was to shift it threw a code they tried to reflash the pcm and it would not take so I am leaning towards a bad pcm??
MR HYDROSEED
Mar 20, 2009 12:08 AM
02Texas_Rattle
27
Dec 29, 2003 05:05 PM
