2wd
Old Jan 10, 2013 | 09:07 PM
Beastly5.9's Avatar
2wd
i have a 1996 5.9 5 speed with 2WD and i want to convert it to 4WD.. can anyone help or tell me what i would need to make this possible? thank you!
Old Jan 10, 2013 | 09:44 PM
9812vram's Avatar
That's a pretty involved question and a whole lot of work. Probably be better to sit back and do a bunch of research on here for a few days. Read up as much as you can, and then ask the specifics if you're still game for it. I searched out a couple just to get ya started...
https://www.dieseltruckresource.com/...4wd+conversion
Old Jan 11, 2013 | 07:50 AM
patdaly's Avatar
Start with a frame.........
Seriously, unless you want to custom fab something up using leaf springs, this swap is way past worth doing.
Old Jan 13, 2013 | 05:14 PM
ronnie's Avatar
often it is better to just get a truck that has four wheel drive.
just the short list, many little things too
drive shaft, both front and rear
transfer case
differant tail shaft/housing for your trans, might be better to get the trans and transfer case together
axles
springs for front and rear
steering linkages
shocks
spring mounts
Old Jan 25, 2014 | 06:22 PM
ihc4bt's Avatar
Is your truck a Cab and Chasis or is it a regular 2wd pick-up. The cab and chasis trucks are easy to convert. The front suspension is the same as a 4wd. Swap axles and use a 4wd trans transfercase. Then put the shifter through the floor. The independent front suspension w a arms is a lot more involved
90 power ram
May 23, 2011 02:44 PM
Jordan5687
Feb 18, 2009 02:48 PM
Bobcat698
Apr 1, 2007 10:26 PM
Craig93
Mar 25, 2003 10:01 PM
R-O-B
13
Mar 16, 2003 11:59 PM
