2nd gen transfer case problem 97 dodge
Old Dec 31, 2012 | 12:54 PM
97DodgeSmokin's Avatar
so i have a 97 dodge cummins 5 speed 5.9 12v that I got in july and i think my T-Case went completely out i can shift into all the gears including 4wd but the truck wont move...does anyone have any suggestion on what to check before i pull her apart?
Old Dec 31, 2012 | 02:27 PM
patdaly's Avatar
If you can feel detents in all of the TC positions, I would suspect a broken trans output shaft, perhaps a weld job on the 5th gear nut?
Old Dec 31, 2012 | 04:47 PM
Tate's Avatar
Could be a number of things. Could be a broken clutch, broken input, broken mainshaft, input in the t-case. You could pull your shifter out of the tranny, engage two gears and try to rotate the driveshaft (rear end off the ground/2wd). If its locked up, then you're looking at the input or clutch failure. If it turns freely, you're looking at mainshaft or t-case failure.
Old Dec 31, 2012 | 05:46 PM
Is there any vacuum lines that might cause it? Like the 4wd line.
Old Dec 31, 2012 | 06:59 PM
Tate's Avatar
No.
Old Dec 31, 2012 | 10:26 PM
ok thanks for the info guys...i just got it pulled out and its looking like it is the transmission
Old Jan 4, 2013 | 11:30 PM
scratch that it was the clutch
CTD2001
Feb 3, 2007 01:30 PM
alltimelow1
Mar 30, 2005 08:18 PM
1st gen Hobie
Nov 10, 2004 02:03 AM
