241 DLD t/case chain slip
Old Feb 27, 2007 | 01:54 PM
Ram of Steel's Avatar
I would like to know if anyone has experienced what presents itself as a badly slipping (bang, bang, bang) transfer case chain only to find out that it was a $5 easily accessible snap ring that was causing the problem?
Transfer case in question is a 1998 New Process 241 DLD from a 1998 2500 CTD and NV4500
Thanks.
Old Feb 27, 2007 | 07:10 PM
rhino 660's Avatar
please tell me more and which one my exact symptoms t- case is in pices
Old Feb 27, 2007 | 07:26 PM
fruitcakesa's Avatar
My 95 CTD had noisy tcase that was caused by a broken snapring. Local trans shop did the fix and used a Ford Snapring as a replacement claiming it is higher quality than oem.
Old Feb 27, 2007 | 10:42 PM
Crimedog's Avatar
The snap ring is not uncommon to break. It's in the rear output housing of the T case. There is a snap ring elimintor kit that you can buy, I don't remember how much it is I want to say around $50 or so. Don't worry, you're not the only one to have this happen!
Old Feb 27, 2007 | 10:46 PM
rhino 660's Avatar
where can i get the kit
Old Feb 27, 2007 | 11:09 PM
Crimedog's Avatar
I just found it, you can get it HERE for $40. It's called the Transfer Case Saver.
Old Feb 28, 2007 | 01:53 PM
http://www.transfercases.com/
I found a great group of guys at Transfer Case Express. They are located in Oakland, Ca. (near San Francisco) They were very helpful and did not want to sell me something I didn't need. They have a minimum of $20. A new snap ring and seal cost me $20.
Hopefully, since it has been snowing quite heavily at my home, I will complete my T/case project this weekend and return my truck to a 4x4.
Old Feb 28, 2007 | 08:01 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya my snap ring just let go last week, took out everything So now I have the up grade for the snap ring. And all new gears, syncros, and blah blah blah.
Old Mar 5, 2007 | 11:52 AM
The snap ring was in good shape but I replaced it anyway.
The problem ended up being the gasket between the t/case and tail housing. It is a fairly thick gasket that is impregnated with silicone.
When I swapped in the NV4500, I switched t/cases as well. I had to swap tail housings so I could hook up the speedo. My old transfer case 241 DHD had the nice thick gasket in it so I swapped it to the 241 DLD with the tail housing.
Don't do that! The thickness of this gasket was causing the problem.
J Lent
Jul 1, 2010 12:39 AM
RichN
Feb 22, 2009 10:48 PM
ram 2500
Dec 8, 2008 08:07 AM
ram 2500
Dec 7, 2008 12:45 PM
