1995 100,000 mile's Time for a clutch ?
Old Apr 1, 2009 | 08:23 PM
Outlawcuda's Avatar
Need some advice,I have a 1995 3500 with 100,000 miles . I use the truck to pull a 40ft enclosed trailer ,weight around 12,000. I think I am getting to the point where the clutch is going to have to be replaced. I would like to do the repair in my shop at home. Can the shifter be removed with out a special tool ? The Diesel is all stock . I see there are complete hyd. kits and complete clutch sets. Can you share your experance with these?
Thank You
Old Apr 1, 2009 | 08:42 PM
louddodge's Avatar
It does not take anything special tools to remove the shifter. I did mine and replaced the clutch at 83,000. To much right foot. The clutch I have now is ok but I would not go with a full faramic for pulling a trailer. The thing is a little grabby.
Old Apr 2, 2009 | 10:03 AM
infidel's Avatar
Depending on your driving the clutch might have quite a few more miles on it.
If you're mostly highway, not too much more power above stock and easy on the accelerator you'll have very little slippage = clutch wear.
Old Apr 2, 2009 | 04:18 PM
Fueling around's Avatar
Area Redwing boot truck got over 200k on the stock clutch pulling a similar sized trailer.
Old Apr 2, 2009 | 04:24 PM
carl48's Avatar
we have over 600,000 on stock clutch pulling similar, it's the driver not the load
Old Apr 2, 2009 | 06:44 PM
Outlawcuda's Avatar
Is there a way to inspect the clutch with out pulling it all apart? When I am not pulling and push the clutch pedal down about 2" it starts to slip. ?
Old Apr 12, 2009 | 08:16 PM
cmac's Avatar
it is doing that because it is starting to disengage. and no there is no way to look at it without un bolting the tranny
Old Apr 13, 2009 | 06:11 AM
Common's Avatar
Thats all I get out of mine and its new.
Pedal position won't tell you anything.
kenni
62
Mar 11, 2012 08:46 AM
Commatoze
Aug 19, 2004 04:00 PM
rocky742
Apr 7, 2004 11:47 PM
Joseph H. Smith
Jan 30, 2004 03:59 PM
MR. GADGET
Mar 4, 2003 07:07 PM
