12 v timing?
Old Aug 17, 2010 | 01:03 AM
co9343's Avatar
Cool 12 v timing?
i have a 95 12 valve with an automatic and i need to know what the stock timing setting is? also should i bump up the timing with bigger injectors?
Old Aug 17, 2010 | 06:23 AM
toms73novass's Avatar
It should say on the data plate on the timing cover...
Usually the recommended setting is about 16 deg.
Here is the chart for timing settings.
Old Aug 17, 2010 | 12:15 PM
nuttynotty's Avatar
Err is'nt the timing in a 12v 1995 supposed to be between 12~13degrees or 4.2mm or .165" from TDC ?
Old Aug 17, 2010 | 03:32 PM
Tate's Avatar
Thats a 180 pump spec, which is a 96-8 auto. 94-5 is the 160/175 pumps.
Old Aug 17, 2010 | 07:36 PM
I think you should be at 5.7-5.8 stock
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
