s300 and 435 injectors
im finally getting my truck finised up and will post pics when its done, its an 04 crew long bed with a 97 12v nv4500 and transfer case, any way i picked up a s300 at work and im going to put it on when i get the truck on the road and all the bugs worked out. my question is will a s300 cool a set of 435 injectors a 100 plate or will it get to hot thanks it also has 4" exhast, bhaf around 16 deg timing and a 4k gsk im chomping at the bit to get her finished up, ive drove it a bit but more work to get guages all working and dont have internet at home yet to post every thing
i dont know how big the wheels or the exhuast housing is, the tag is hard to read, i tried to clean it, still fairly hard to read if i can read the serial number is their anyone that could tell off of that
There are 6 different comp. and and turbine wheels for the 300 series turbos.
You have to either get some numbers or measure the wheels.
I ran a 62/65/14 S300 and the 435s were hot. Dont get me wrong, you can always drive with your foot to keep temps down.
Do you have head studs? If so, I would bump your timing up.
Bigsmoke3500
12-04-2008 08:35 PM
Wild Wills CO
08-04-2007 11:41 PM
