s300 and 435 injectors
im finally getting my truck finised up and will post pics when its done, its an 04 crew long bed with a 97 12v nv4500 and transfer case, any way i picked up a s300 at work and im going to put it on when i get the truck on the road and all the bugs worked out. my question is will a s300 cool a set of 435 injectors a 100 plate or will it get to hot thanks it also has 4" exhast, bhaf around 16 deg timing and a 4k gsk im chomping at the bit to get her finished up, ive drove it a bit but more work to get guages all working and dont have internet at home yet to post every thing
What wheels are in the S300? That will determine how good it will keep the egts in check. If it's not a 62 compressor or bigger it will probably be warm.
My notes say the s300 is a 57/65/14. Exhaust housing can prob vary between 12, 14, 16 like most others will.
i dont know how big the wheels or the exhuast housing is, the tag is hard to read, i tried to clean it, still fairly hard to read if i can read the serial number is their anyone that could tell off of that
There are 6 different comp. and and turbine wheels for the 300 series turbos.
You have to either get some numbers or measure the wheels. I ran a 62/65/14 S300 and the 435s were hot. Dont get me wrong, you can always drive with your foot to keep temps down. Do you have head studs? If so, I would bump your timing up. |
