Quadzilla Adrenaline
Old 11-17-2015, 04:46 PM
ramcummins's Avatar
Is anyone still using this tuner? I'm having some troubles with mine. As soon as my coolant hits 203 degrees my tuner completely shuts down and kills my engine power to below stock power. Any ideas?
Old 11-17-2015, 08:40 PM
high bid's Avatar
Check the settings...there are adjustable limits which control it.
I'd also check coolant level, water pump and thermostat. I don't believe temps should or need to be that high.
Old 11-18-2015, 09:36 AM
ramcummins's Avatar
Thanks for the quick reply. The only time it gets that hot is when I'm pulling a load up a hill. Maybe I'm wrong but I didn't figure 203 was unreasonable given the pull??? I will check the coolant and t-stat though. As for the settings on the tuner, shouldn't they just cut the additional power back to stock and still have power to the monitor of the adrenaline? It totally shuts everything off (no chip, no monitor, nothing). Also cuts the stock power back as if the ecm isn't reading any boost.
Old 11-18-2015, 09:30 PM
high bid's Avatar
I'd check the normal operations first to make sure all are working properly. Those temps seem high even in winter and towing. My truck towing up hill in south Texas summer and I'll only hit 205* for a short time.
If everything is shutting off, then it sounds like you may have a short. When it shuts off it is probably eliminating all the signals to/from the ecm and thus causing more issues.
I'd disconnect it, check all the factory stuff and then go from there. Do a coolant flush,check water pump, thermostat and the backside of the radiator to see if it's clogged up.
Good luck
Old 11-18-2015, 11:55 PM
ramcummins's Avatar
Thanks for your help, I'll check these things first.
Old 11-19-2015, 07:42 AM
high bid's Avatar
Go to the top left of the site, click on "user cp" and fill out your signature so we know more details about your truck.
Old 11-23-2015, 08:37 PM
ramcummins's Avatar
Sorry about the signature. It used to be there. I haven't been on here for a couple of years, something must have changed, also it looks different than it used to cause I'm doing it on my mobile instead of my computer... I'll log on with my computer and get that fixed.
I checked my coolant, thermostat, ect... It all seems to be working normal.
Old 11-23-2015, 08:56 PM
ramcummins's Avatar
Weird, I logged on with my computer and went to change my sig, but it was still there. I'll try this post with my computer and see if it showes up.
Old 11-24-2015, 08:10 PM
ramcummins's Avatar
Looks like the signature works when posting from computer but not mobile
mopar440cu
11-21-2015 08:39 PM
Smokin98.5
0
05-29-2008 05:35 PM
dodgediesel
43
01-20-2008 01:05 PM
99Silver Bullet
01-14-2008 01:04 PM
Bobcat698
01-10-2008 06:54 PM
Quick Reply: Quadzilla Adrenaline
