20* timing
Old 09-06-2009, 03:41 PM
YOUNG GUNS15's Avatar
20* timing
ok, so i went to the dyno event at weekend on the edge over in ogden utah, there was a guy there running 50lbs of boost(cant remember the turbo) on 20* timing with a STOCK headgasket!! so my question to you is this.
is it possible to do 20* on my truck? reliably?
Old 09-06-2009, 06:01 PM
graphitecumnz's Avatar
Originally Posted by YOUNG GUNS15
reliably?
doubtful... was he running head studs?
Old 09-07-2009, 10:04 AM
97DodgeRam's Avatar
You could do it and it might last forever. Or the head gasket might pop the first time you get on it. With 253000 miles on your truck, I don't think it would be too reliable. You might be able to retorq your head and run 20* of timing for a little while before the head gasket goes.
Old 09-07-2009, 01:02 PM
update: i have 258k on it, and no he does not have studs, i want to do this but i dont want to strand myself somewhere
Old 09-07-2009, 02:03 PM
I'm not sure these two statements can coexist...
Old 09-10-2009, 10:09 PM
heykw's Avatar
I say go for it retorq the head and let her eat I am fixing to do the same thing on my 98
Old 09-11-2009, 04:51 AM
gwhammy's Avatar
I would say if the head has been decked flat and the deck on the block is flat it is possible. Some retorque of the bolts just to be sure they are as tight as they can be. I ran 20 degrees and 65 for a while on stock gasket and studs.
Old 09-11-2009, 08:47 AM
which is better for rpms? 18* or 20* without sacrificing low end torque?
Old 09-11-2009, 02:36 PM
gwhammy's Avatar
I ran 17 then 20, I really liked 20 alot with twins and the fuel I was running.
Old 09-11-2009, 04:01 PM
Tate's Avatar
Some head gaskets will take a lot stock, some not so much. There are lots of guys pushing 550+hp on stock head gasket and bolts. Just got to be prepared for when it fails. It might never fail on you, but it will always be in the back of your mind.
Old 09-13-2009, 08:09 AM
when i advance it will my horse power to torque ratio go down? right now im almost at 3:1 292hp 777tq
GR40RCapri
07-24-2006 11:47 PM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: 20* timing
