Radiator leaking severly behind fan shroud
Old 08-31-2005, 12:18 AM
Kass's Avatar
Found leak in radiator behind fan shroud of my 2003 Dodge Ram 2500 P/U. I Removed the shroud and found the electrical support wore into the radiator. I ground off some of the plastic material which gave the needed clearance.
Need to know if a radiator sealer will be a permanent fix or does the rad need to be repaired?
Dodge needes to inform its customers on these issues.
Kass
Old 08-31-2005, 05:31 AM
59FORD's Avatar
WELCOME aboard KASS
Have the radiator soldered and just say no to cheap fixes.
Sealer is a TEMPORARY "fix" NOT a repair.
natstayl's Avatar
Is it possibly still under 7/70 warranty? I agree Dodge ought to take care of it (unless you relocated it doing mods). I wouldn't trust sealer, if it's not under warranty I would order another rad online or take it to a trusted rad shop. Keep us updated and by the way... Welcome aboard Kass. Where are you located? Fill in some info on your personal profile so we know how close to other members you are.
Nat
Old 08-31-2005, 05:37 AM
Rauschbo's Avatar
I tried a popular brand Stop Leak in my old 280Z radiator - it stopped the leak for a while, then the radiator literally BLEW, it looked like somebody hit it with a shotgun. I recommend fixing / replacing the radiator!
11-18-2009 05:44 PM
BurrisWill
01-20-2009 10:43 PM
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
TurnerBurn
03-04-2006 01:15 PM
Quick Reply: Radiator leaking severly behind fan shroud
