Sponsored by:
Sponsored by: DashLynx
Boost psi?
Old 10-01-2015, 07:53 PM
Caleb05's Avatar
Boost psi?
Im just curious what my boost gauge should be reading. It reads 19psi maxed, just seems a little low to me. 2005 2500 smarty so6 pod stock turbo and injectors upgraded trans on 35in toyo mts
Old 10-02-2015, 12:38 AM
FastTaco's Avatar
I got 42 psi out of my stock turbo with smarty. Make a lot of smoke? Might have a leak.
Old 10-02-2015, 05:24 AM
Caleb05's Avatar
It only smokes when I lug it or lay into it. Wouldn't you notice a power loss if there was a leak? Also I think the waste gate might be going cause once in a blue moon it throws an underboost code but as soon as you clear it there's no problems.
Old 10-02-2015, 08:48 AM
verdesardog's Avatar
should be getting closer to 30 wide open throttle.....won't stay there though as you accelerate.
Old 10-04-2015, 11:10 AM
michael/edge's Avatar
without the smarty you should see 23-25 psi max.
Old 10-05-2015, 04:33 AM
Caleb05's Avatar
Okay so there's obviously a problem. I run the smarty pod so6 on level 7 cause I like the power and throttle response. About once a month I'll get a P0299 underboost code and loose all power but as soon as you clear it there's no problems. Should I just bite the bullet and upgrade the turbo?
Old 10-05-2015, 09:46 AM
BILTIT's Avatar
Check for boost leaks and see if your wastegate is sticking open.
Old 10-06-2015, 07:08 PM
Caleb05's Avatar
What's the best way to check for leaks and to see if the waste gate is sticking open? Old soapy water trick?
Old 10-06-2015, 10:49 PM
CRF450R RIDER's Avatar
first you can visually look for any loose, cracked or broken parts. if you can rig up a way to blow air into from an air compressor, then blow like 40psi from a compressor in there. then listen for any leaks.
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: Boost psi?
