Cruise control don't work. how to diagnose??
Old 09-13-2010, 09:00 PM
Robert Rausch's Avatar
BTW, on my '95 when the clockspring went out it was very obvious.
Old 09-14-2010, 12:11 AM
GCSS's Avatar
care to elaborate?
Old 09-14-2010, 02:46 AM
Well, it was 8 years ago, but as I recall the turn signals went out, and/or the cruise control. And there was a "sprong" sound when turning the wheel.
Old 09-14-2010, 06:39 AM
GCSS's Avatar
I used to work as a mechanic at a Chrysler dealership and forgot more than what most people know. I remember replaceing one of them, but don't remember WHY.....
chuckle of the day I guess??
Old 09-14-2010, 10:09 AM
infidel's Avatar
There was a recall on many 2001 Chrysler vehicles due to a bad batch of clocksprings.
My bet is at least one of those must have passed your way.
Old 09-14-2010, 11:04 AM
GCSS's Avatar
Actually it was from the timeframe of 1995-1997 when I worked there, I do recall having my clockspring recalled on a 2001 Dually I used to have though.
Old 09-16-2010, 02:48 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
As said the problem is usually the vacuum line under the battery. It is very difficult to check by just looking without removing the battery and tray. Best way is to pull the hose off the cruise actuator and bring it out where you can see it better.
The clockspring problem is rare in the 12 valves, more often occurs in '98 and newer years.
Second most common problem is a bad brake light switch. The switch has three sets of contacts, brake lights can work fine but not the cruise.
Sometimes you can diagnose a bad switch by lifting up on the brake pedal with your foot while engaging the cruise.
I find it's easier to just replace the switch, fast and cheap.
The switch is $11 at Napa.
Not highjacking the post..Got my cruise working...Mine was a switch..Pulled up the brake pedal and my cruise works...Thanks Bill...
Old 09-16-2010, 03:01 PM
cmac's Avatar
Not sure on '96 but '94 & '95 have no on indicator lights at all.
96 and 97 models have a little light next to the cruise on/off switch that illuminates green when turned on. my 98 has the light on the dash that says "cruise" and its green, i would guess the rest of the second gens are the same.
Old 03-17-2017, 06:00 PM
Josh Winkler's Avatar
95 cruise not working
so i did a complete dash swap from another 95 and now cruise wont work changed clock spring brake light switch and cheked vacum all seem to be fine till no cruisee any suggestions
Old 03-19-2017, 12:33 PM
SIXSLUG's Avatar
Retrace all steps, check with multimeter....
Old 03-19-2017, 03:31 PM
Ended up having some differences in harness donor truck was late 95 and my truck early 95 had to put factory harness back in all works right now thanks
keith1992
07-13-2008 04:03 PM
NoSparkplugs
05-25-2007 02:42 PM
NoSparkplugs
10-16-2006 10:59 PM
GCSS
08-14-2006 12:29 AM
Quick Reply: Cruise control don't work. how to diagnose??
