2001 EX 5-speed (speedometer/tachometer/cruise control/starter don't work)
Old Feb 25, 2009 | 06:59 PM
stock03's Avatar
I have a 2001 EX 5-speed. A few hundred miles after I changed the clutch, the speedometer/tachometer/cruise control all stopped working. Yesterday, the car wouldn't crank over at all. It seems like a dead battery, but the battery is brand new. The starter sometimes clatters, but will NOT turn the motor. When I push start it, it starts right up and runs great.
Any advice?
I also posted this on a Honda site. But I'm hoping someone here may also have some advice.
Thanks your help!
Old Feb 26, 2009 | 07:49 AM
Hvytrkmech's Avatar
Check your grounds, also check for crushed or pulled wires. It seems to me that you may have missed reinstalling one when putting the tranny back in.
Tach signal should come from either the cps or the cam sensor. The speedo pick up is usually located on one side of the tranny near the axle shaft. A neutral safety switch will also cause a no start, but you will be able to pop start is as you have. I would find it hard to believe that you had multiple different failures at once, that is why I suggested checking all the grounds.
Tim
Old Feb 27, 2009 | 09:42 PM
Hvytrkmech's Avatar
How did you make out?
Tim
GCSS
25
Mar 19, 2017 03:31 PM
Landini1
Mar 6, 2009 07:01 PM
dansdodgediesel
Dec 22, 2004 05:49 PM
cumminsdriver635
Aug 24, 2004 08:29 PM
sam
Mar 31, 2003 09:04 PM
