tranny leak when in park
Old 01-26-2014, 11:37 PM
dubc2323's Avatar
when I warm up my truck, if I leave it in park the transmission will start leaking in about 5 mins. but if I start it in neutral, it doesn't leak. apparently the pump kicks on in neutral but not park? as for the leak I pulled the inspection plate off and it leaks behind the torque convertor....but only when idling in park. any idea's
Old 02-01-2014, 12:36 PM
dozer12216's Avatar
Is the tranny overfilled??? An it's leaking enough to tell it comes from behind the converter!! you will have to remove tranny to fix. I would get some leak detection dye in install a few minutes before removing trans. If you let it run to long it will be all over the housing and no clue where it came from.
Old 02-02-2014, 01:05 AM
dubc2323's Avatar
the fluid level is fine but the one time I actually went to check where it came from I pulled the dust cover/inspection plate off and it looked like there was a stream running down from there in the inside part of the casing. usually it's no big deal as I just put the tranny in neutral and set parking brake to warm it up, but the one time I forget that the thing leaks was in someone elses driveway when I forgot to put it in neutral.
davelinde
07-23-2009 08:16 PM
wcbcruzer
12-17-2008 08:38 PM
Spooler
19
03-28-2008 01:54 PM
04ctd
12-01-2006 06:48 AM
satburn
10-04-2006 03:26 PM
Quick Reply: tranny leak when in park
