Help!!! New tranny... vibration in park at 1900 RPMS?
Old Mar 26, 2008 | 05:30 PM
Spooler's Avatar
Just found an issue I need an answer for. After my tranny upgrade they turned on the manual high idle. I tried it out and noticed a vibration while in park. I killed the manual high idle and pressed the go pedal. Right at 900 rpms I have a vibration. I don't think it is normal so I am asking. The guy that did the install had a class today in Atlanta. Need info if this is normal or do I have an install problem. No vibration at all while in Reverse or drive. I didn't try neutral.
Oh yeah, I tried to get ahold of Dave today, no luck. I waited to long in the day. Been very busy at work.
Old Mar 26, 2008 | 05:42 PM
Kman9090's Avatar
What about when you are driving?
Old Mar 26, 2008 | 06:00 PM
Spooler's Avatar
Well, I just went out and fired it up. It does it in all gears with the brake mashed. Back to the shop tomorrow. Should of drove to Iowa!!!!!!! Aggrivating!!!!
Old Mar 26, 2008 | 06:07 PM
LFD2037's Avatar
Why are you revving it to 1900 RPM's in park?
Old Mar 26, 2008 | 06:18 PM
lmills's Avatar
Just got off the phone with Dave, he will be contacting you shortly.
Old Mar 26, 2008 | 07:18 PM
Spooler's Avatar
Sorry, I have been out dealing with the horses and still am. I will call him tomorrow. Not his fault. I should of done it myself. That's why I was a mechanic a few years ago. I am picky.... If you want it done right do it yourself....LOL I went against the grain and it has reminded me of such .... No big deal....
I will pull the inspection cover tonight and see if I can catch any wobbling of the flexplate or converter. If nothing, tranny has to come out.
Old Mar 26, 2008 | 11:44 PM
Spooler's Avatar
I did get ahold of Dave tonight. Pulled the inspection cover and converter was doing the funky chicken. Pulled all the TC bolts and the converter moved backwards on it's own. Spun it a half a turn, slid it foward to make contact with the flexplate, installed all 6 bolts finger tight, and then tighten them down. Problem solved. It's the silly stuff that gets folks.
Oh yeah, I made a typo on the first post. Vibration was at 900 RPM not 1900.
Old Mar 27, 2008 | 06:22 AM
LFD2037's Avatar
Did you put lock-tight on the flexplate bolts?
Old Mar 27, 2008 | 11:17 AM
Spooler's Avatar
All I had was red loctite. Didn't want to loctite them unitl I knew the problem was corrected. I'll keep an ear out for them and will do it later if necessary.
Old Mar 27, 2008 | 11:21 AM
elirandolph's Avatar
so was the converter not seated right against the flexplate or was something bent?
Old Mar 27, 2008 | 11:24 AM
Spooler's Avatar
Wasn't seated right, hence the funky chicken dance of the converter/flexplate. Not bad but noticeable.
Old Mar 28, 2008 | 12:05 PM
so is everything good now?
Old Mar 28, 2008 | 12:48 PM
Spooler's Avatar
Yeap, it's good to go.........Like I said a overlooked install problem that just got solved....
Old Mar 28, 2008 | 12:51 PM
ian515's Avatar
why iowa? is there a good shop here I am unaware of?
Hounddog's Avatar
How about posting how the trans works and what differance in stock etc.
