A/C Compressor retrofit...Non-IC to IC
Old 10-22-2011, 02:32 AM
  #31
jimbo486's Avatar
Another difference is in the a/c compressors. The non i/c, C-171 compressor sits slightly lower due to the bracket (aka water inlet connection) and also has a larger pulley compared to the i/c, Sanden SD709 compressor. Hence, the need for a longer belt. Which is also why, in 1990's case, the belt touches itself because the tensioner has more slack to take up.
Old 10-22-2011, 06:00 AM
  #32
Jim Lane's Avatar
Post Cummins Drive Belt Information.
****************Belt Length Gates # Dayco #
1990-91 Without AC 64.50” 80645 KO80645 5080645
1990-91 With AC>> 81.50” 80816 KO80820 5080820
1991.5 Without AC 63.50” 80635 KO80635 5080635
1991.5 With AC>> 83.00” 80830 KO80830 5080830
**Note the factory parts manual lengths are different from what is suggested by the belt manufactures.
1990-91 Without AC Dodge recommends a 64.85” belt.
Gates recommends a 64.50” belt.
1990-91 With AC Dodge recommends a 81.75” belt.
Gates recommends a 81.50” belt.
1991.5 Without AC Dodge recommends a 00.00 belt.
Gates recommended 63.50” belt
1991.5 With AC Dodge Recommends 82.09” belt.
Gates Recommends 83.00” belt
Dayco Belt Tensioner:
#89005 Replaces the Idler Pulley Only Approx. $22.00
#89219 Complete Tensioner Assembly Approx $100.00
All of the belts above range from $36.00 to $50.00
To help decipher the manufactures part numbers,
Example: 80645 belt
KO 80645 Gates
50 80645 Dayco
To find the length of a belt:
KO80645 = 64.50” belt
KO80830 = 83.00 belt.
This should make it a bit easier to figure out the size of your belt for your conversion.
I will correct or add to this as I collect information.
I will also see if I can put this in the sticky for future reference.
Jim
Old 11-03-2011, 05:57 AM
  #33
1990's Avatar
So i got a new Gatorback belt. Just over a 1/8th inch of clearance between the tensioner and the belt running down to the a/c compressor.
I'm thinking of making up small spacers for the compressor.
Old 06-06-2014, 06:40 AM
  #34
Jim Lane's Avatar
Jimbo,
I know this an old thread but how did you finally get all of your new hose and fittings connected?
How is your system working?
Did you use your factory evaporator?
Mine had a leak so I had to replace it with an aftermarket unit, what a nightmare, I rejected about 5 or 6 of them before I got one that I felt I could use, I had to rebend the lines to even get it in the case.
How have you been?
Thanks Jim
Old 06-06-2014, 02:54 PM
  #35
Received 1,332 Likes on 862 Posts
I think Jimbo went to the complete IC style A/C system when he converted the truck to the IC front end. But I could be remembering it wrong?
Old 06-06-2014, 06:38 PM
  #36
jimbo486's Avatar
Brian, you're correct. I did convert over to the Sanden SD709 compressor after converting the entire front end and engine to factory i/c. I just bought the crimp fittings I needed to fit the compressor and barrier hose (-10 and -8, IIRC). Nothing inside the heater box changed, still using the factory evaporator. Bought a new dryer for the system as well since its recommended to change if the system is ever exposed to atmosphere.
My friend who was in the automotive heating/cooling business for 30 years had the hose and crimp tool needed to build the lines. He borrowed the flanged ends at the condenser and evaporator to have the crimps brazed onto the steel or aluminum tubing (I forget the material).
We built everything at his house, ran the lines away from any potential damaging sources, bolted everything in place and charged the system with R-134a and a fluorescent dye to detect leaks at any time.
The system has been running great and gets plenty cool enough for me!
I've heard quite a few stories about the aftermarket evaporator cores fitting like crap and the supply and return tubes aren't quite the correct angle they should be.
Hunted and pecked from a Galaxy S4A.
Old 02-16-2015, 06:06 AM
  #37
Jim Lane's Avatar
I don't think there is any difference in the tensioners between Non-IC and IC motors. I think the main differnce is in the fan hub. AS for part number....will see if I can find something.
I know this is an old post but it has been ongoing,
I have recently converted my truck to the Sanden SD-709, everything has fit together nicely but what I have discovered,
I was able to use my existing K080830 belt and it fit but it was tight, see how close the idler is the the belt, I need you to tell me how close yours is on your truck so I can have an idea if mine it too tight or not.
What I find is although the tensioners are the same, there is a hole on the bracket where the tensioner indexes is in a slightly different location on the new intercooled bracket clocking the tensioner pulley at a new angle where a shorter belt might not fit over the tensioner and a longer belt might cause the belt to rub, still under the experimental phase.
I want to be careful and not put too much tension on the new compressor bearing by loading the belt to tight, I am sure I could re-index the tensioner if I had to, anyone else have this issue, I will not call it a problem.
Jim
Old 02-16-2015, 11:47 AM
  #38
jimbo486's Avatar
I'm at work today but have my truck with me. Give me a few hours and I'll check the gap you mentioned.
You might be on to something with that. Looking closely at the pictures in Brian's first few posts, it appears that the index "notch" on the non i/c water inlet connection is 90* to the block. Whereas, the index "notch" on the i/c water inlet connection is at a slightly downward angle. That angle does appear that it would index the tensioner and pulley as such, closing the gap between it and the belt on the passenger side of the alternator and a/c compressor pulleys.
Old 02-16-2015, 12:11 PM
  #39
j_martin's Avatar
Jim
I think you'll find that the tension difference between just off the stop, and fully wound is very little. Total travel on the tension mechanism is a fraction of total travel on the spring within it.
Old 02-16-2015, 04:30 PM
  #40
jimbo486's Avatar
Jim,
I'm assuming when you converted, you only changed over to the i/c water inlet connection and the SD709 a/c compressor. Correct? You still have the non i/c fan hub/pulley bracket which moves the fan hub/pulley towards the driver side slightly? To the right if you're facing the engine from the front, looking down at it. The i/c fan hub/pulley bracket appears to be centered directly in front of the 4 bolts holding it to the block.
Believe it or not, the non i/c, a/c belt is actually shorter (81.6") than the i/c a/c belt (83"). Strangely, there's only a 1" difference between the non a/c belt for the 2 types. These are the numbers I'm coming up with from a quick search.
Anyhow, I have the i/c fan hub/pulley bracket on my motor along with the water inlet connection and SD709 compressor. I'm utilizing the Gates K080830HD belt and a tensioner, of course. The tensioner is the same from '89-'02, according to Geno's Garage. I didn't notice a lot of slack to take up when I slipped the belt over the alternator pulley. The attached picture shows you where my tensioner sits.
Attached Thumbnails A/C Compressor retrofit...Non-IC to IC-20150216_122542.jpg
Old 02-16-2015, 04:35 PM
  #41
Jim Lane's Avatar
The first thing I do is compare and document everything
Here is the new bracket that I installed, here the slot is maybe a 1/2" off towards the bottom of the block, .
And now here is the old bracket, see how the slot is almost straight across from the bolt tensioners bolt hole, with the length of the tensioners arm the pulley has now moved a decent amount.
As it sits I am not overly concerned about the tension but I do not want to put any unnessicayr load on it either, but if I want to make the belt a little longer so it easier to get on then the belts might rub.
I was thinking I could cut the slot a little wider back towards centerline, tension should pull towards the new cut, correct?
I would use my 4" angle grinder to make the cut.
Has anyone else run into this problem, I do not think a 2nd gen fan pulley would make any difference as far as the location of the tensioner pulley.
Jim
Old 02-16-2015, 04:53 PM
  #42
Jim Lane's Avatar
Jim,
Jim,
We must have both posted at the same time, if you look at the back of the tensioner you can see the paint markings from where it used to set on the old bracket, my belts have always a little different because I have the Leece Neville alternator, I think reclocking the tensioner notch will fix the problem.
The K080830 belt fits and if the tension is ok I would still like to make it a bit easier to install the belt in case of an emergency and I did not have all of my special tools with me.
Jim
Old 02-23-2015, 06:01 AM
  #43
Jim Lane's Avatar
To answer your question, Jim (if it's not too late), I spoke with my friend over the weekend, who has been doing automotive a/c work for 30+ years. For every 1lb of refrigerant, there should be 3.25oz of refrigerant oil added to the mix. I'll verify those numbers when I see him again tomorrow and confirm.
I also just got back from picking up a new Sanden SD709 compressor and all the fittings I'll need for my retrofit.
Using my friend as a reference, the price of the compressor was cut from $284 to $203 (before tax). All the fittings and ferrules came out to only $51. Total with everything only ran $270. My friend has the crimping tool and all the #6, #8 and #10 barrier hose I'll need. In order to take advantage of the 1 year warranty that covers the compressor, I need to replace the dryer which I'll buy tomorrow along with a new belt for a/c. Then, I'll head to my friend's house, start cutting and crimping some barrier hose and charge the system.
Hey Jimbo,
I need you to think back a few days ago, when you got the AC fittings for your new Sanden SD-709 compressor.
I understand the fittings are #8 and #10 at the compressor, but what is the thread pitch, are they a standard
#8 = 3/4"-16
#10 =7/8"-14
OR
are they metric?
I bought the NEW SD-709 from Oreillys
Murray #78594
Nobody can seem to give me an answer, they can come either way.
When did the truck become metric?
Do you have an pictures of your new lines?
Thanks Jim
Old 02-23-2015, 07:00 PM
  #44
jimbo486's Avatar
Jim,
The spec sheet for the Sanden SD7 series compressors is listing them under the torque specs to be SAE; #8 - 3/4" and #10 - 7/8".
Pictures of the lines can be found in my retrofit thread.
https://www.dieseltruckresource.com/...trofit-296200/
Old 10-28-2017, 02:59 PM
  #45
Archived.....link below if pics stop working.
https://web.archive.org/web/20171028...-ic-ic-289065/
jimbo486
10-17-2011 05:56 PM
WhoCares79
06-03-2008 11:45 AM
Camarogenius
06-25-2007 08:55 PM
JKM
03-08-2006 03:23 AM
Quick Reply: A/C Compressor retrofit...Non-IC to IC
