'89 Ramcharger 12V 5-speed 4x4 build
Old 01-19-2016, 02:34 PM
  #31
Received 2,392 Likes on 1,576 Posts
Thanks Tman!
The first picture is what I saw when I pulled the cover, no case bolt, no billet KDP tab.
It might have been overkill but I used the 12 pack box to make sure all the bolts returned to there proper location.
Good race day even thought the wind was 20-30 MPH, visibility was little to none and the temp was 5F maybe 10F tops. Most of the lifts where closed due to the high wind.
I took second place snowboarder by only 0.1 seconds, and the rest of the team was in the top 20 for skiers out of about 160 people. We might get a free team dinner out on the town for that sort of showing.
Off to crack a beer, listen to some Iron Maiden and clean off old timing case gaskets in the shop.
Old 01-19-2016, 03:11 PM
  #32
mknittle's Avatar
Who posts pictures of all the great work they do, then when they sell it they pull the parts back out to feel better about themselves.
Not even leaving me the case bolt.
I guess you found out the hard way. Good thing you checked.
Old 01-19-2016, 05:10 PM
  #33
I had the time to clean up the timing case and cover and get it ready it install a new front crank seal and a fresh cover gasket.
If I get a little crazy tomorrow, I might even spray a fresh coat of black paint on the cover.
I also got a '96 P-pumped harmonic balancer I am looking to install as it is bigger and may help dampen things.
It still has the CPS grooves, but is about an inch or more in diameter bigger.
It was something I heard PapeCat mention about using the later year, bigger harmonic balancer to dampen things a while back.
Old 01-19-2016, 08:25 PM
  #34
j.fonder's Avatar
ever since i read t-cows post on his fluid damper, i've wanted one. can't wait for an excuse to switch to it.
Old 01-20-2016, 02:00 PM
  #35
Received 1,332 Likes on 862 Posts
Hahaha....I see I'm not the only one who uses the cardboard bolt placement method....
Mine...
Old 01-20-2016, 02:57 PM
  #36
bigragu's Avatar
Mine...
Awesome pic! Much needed! Wish I had something like this when I tore into mine not too long ago; I saved the pic for future.
This pic, should be posted on the sticky, I feel. Thanks, TC
Old 01-20-2016, 03:03 PM
  #37
mknittle's Avatar
Mine...
I have done it before.
Old 01-20-2016, 05:11 PM
  #38
I am no expert at re-assembly, and I am not to proud to use a "cheat sheet"
to make sure everything goes back together smoothly.
I saw a "professional wrench" use this technique 15 years ago on a head gasket job.
I have been using it whenever it seem worth it since.
I am in no rush, I would like to have it done right at the end of the winter.
Old 01-20-2016, 06:41 PM
  #39
mknittle's Avatar
Good idea with so many bolts that are different. In this case it likely saves time.
Old 01-21-2016, 04:13 PM
  #40
I just finished getting the timing case all buttoned up with a new front crank seal and timing case gasket.
The cheat sheet of bolts on the cardboard make it really easy for me to dab a little RTV on the bolts and thread them in by hand into the right hole the first time.
I then torqued them down to 18 FT LBs.
I am feeling good that I am at least starting to bolt stuff back together on this project!
It would have been nice to paint the outside of the cover before I installed it ,but it was a 10F high outside today and I didn't feel like spray painting in the shop.
Old 01-21-2016, 05:52 PM
  #41
Received 1,637 Likes on 1,112 Posts
................ another beer owed......
Attached Thumbnails '89 Ramcharger 12V 5-speed 4x4 build-photo-2.jpg   '89 Ramcharger 12V 5-speed 4x4 build-photo-3.jpg   '89 Ramcharger 12V 5-speed 4x4 build-photo-4.jpg
Old 01-21-2016, 05:58 PM
  #42
NJTman,
Thanks again!
It certainly makes my thread a little more interesting with those pictures.
I just gave you a call to see how all the pre-snowstorm prep went and also to ask you... What sort of beer do you like?
Old 01-21-2016, 06:20 PM
  #43
mknittle's Avatar
It really is a good feeling when at least some part is going back together instead of apart.
Old 01-21-2016, 06:24 PM
  #44
Nice to finally catch up on the things that shouldn't have even been an issue to start with.
Old 01-21-2016, 07:18 PM
  #45
bigragu's Avatar
That FD post is top notch, J, and I printed ThrashingCows instructions out and followed it to the Tee, and learned a bit along the way and manipulated the part on the fan clutch a tad to get mine to work. TC was even generous to even offer his assistance via PM's when I ran into questions. If and when you do install the FD, you will not be disappointed in the investment of time and $$
Quick Reply: '89 Ramcharger 12V 5-speed 4x4 build
