Voltage Regulator ?
Old Jan 30, 2009 | 04:51 PM
mandtandk's Avatar
Voltage Regulator ?
Ok, I'm a complete idiot when it comes to electrical stuff. I would like to do the voltage regulator bypass thingy. The instructions say to connect the ext. VR to an ignition switched source. Specificly, where does one find such a source?
Thanks in advance
M
Old Jan 30, 2009 | 06:22 PM
infidel's Avatar
It would help to know the year of your truck
Old Jan 30, 2009 | 06:59 PM
nickg's Avatar
next question is why do you want to do the external VR??
Old Jan 30, 2009 | 07:59 PM
mandtandk's Avatar
Oops. Of course. It's a '97 3/4T 4x4.
My GEN light has been coming on. I did a search, and the thoughts were that the system functioned better with this ext. regulator. I thought I would give it a try before I forked out $$$ for a new alternator.
Thanks again
M
Old Jan 30, 2009 | 08:19 PM
Number47's Avatar
its been a while but isn't the voltage reg in the computer?? i know it is on my wife's winter beater 92 dynasty
Old Jan 30, 2009 | 10:51 PM
rebal's Avatar
yup its on the fire wall behind air filter
but it might be time for a new alt. have it tested
Old Jan 30, 2009 | 11:57 PM
torquefan's Avatar
Thanks again
M
The ones in the PCM generally work well and rarely fail. Also, I would think you would tend to get trouble codes and warning lights with a bypass. It is something I'd only do as a last resort, if a new PCM wasn't available. Chances seem to be better that it is just worn out brushes or a rectifier problem on your alternator.
Welcome to the site.
Old Jan 31, 2009 | 02:31 AM
nickg's Avatar
Most places will test an alt for free...
Old Jan 31, 2009 | 06:27 AM
mandtandk's Avatar
Well, I had the ALT tested and it was bad. Due to a time problem, I went ahead and got a new one. Put it on last night and all appears well.
Thanks for the help
M
Old Jan 31, 2009 | 11:14 AM
infidel's Avatar
For future reference the voltage regulation portion of the PCM on 12 valves have been known to fail and a external regulator is a much cheaper way to go.
Works excellent and cost less than $20.
Here's instructions for a 1st gen but they are exactly the same for any PCM regulated vehicle
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Won't fix a bad alternator though
TurboAZ
Aug 27, 2013 09:26 PM
Cooter02
Oct 18, 2004 05:20 PM
Monty
Sep 9, 2003 08:04 PM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
