Voltage Regulator... HELP
Old Oct 18, 2004 | 10:33 AM
Cooter02's Avatar
The ranch truck at the ranch I work at is a 92' CTD 4X2, started eating batteries, more specifically melting batteries. First thought was the alternator went ****-up, but it test fine and according to the alternator shop Dodge moved the voltage regulator from the alternator into the computer, does this sound correct? They are saying the only way to fix it is a new computer!! Lot of money for a very ruff truck. Would it be possible to install an inline regulator?? Any help would be great, I don't know such about 1St Gens. but this truck still has alot of miles left in the motor.
Thanks,
BP
Old Oct 18, 2004 | 11:45 AM
uncleroty's Avatar
On some '92's the voltage regulator is on the firewall above the valve covers, on others it's in the SMEC. In the books it says it's in the SMEC, but I had a friend with one that was a 92 with it on the firewall.
If you have one with it on the firewall, you can do it in 2 minutes for 10 bucks. I'm not sure what an SMEC costs, but that is not too bad a job to do. Good luck with it.
Old Oct 18, 2004 | 12:50 PM
BIGBADBOB's Avatar
Do a search on this site as someone had changed theres out to a firewall style rather than in the brain box. It may have "Haulin in dixie"
Old Oct 18, 2004 | 05:20 PM
Monty's Avatar
Check the tech facts section https://www.dieseltruckresource.com/...n&onlynewfaq=1
Primaris
May 4, 2015 04:14 PM
9MM
Nov 5, 2011 11:26 AM
TexasHardcore
Nov 29, 2004 12:05 AM
Monty
Sep 9, 2003 08:04 PM
