HELP 3rd gear sound 97 dodge cummins
Old 10-18-2014, 12:01 AM
97DodgeSmokin's Avatar
ok so on the way home from the store i shifted into 3rd gear and it is making a really bad grinding sound once it is in gear it sounds like something is touching the teeth on the fly wheel it dosnt do it in any other gear is it the clutch going out or could it be something else 97 dodge cummins 12v 5.9 5 speed
thanks Jesse
Old 10-19-2014, 07:46 AM
gorms's Avatar
If it's only making noise in third it's likely a problem inside the transmission. Bent or worn shift fork would be an easy thing to look for by popping the top cover once the trans is out.
Old 10-20-2014, 02:47 AM
thanks for the info gorms
Old 10-26-2014, 10:47 PM
found the problem with my nv4500
Attached Thumbnails HELP 3rd gear sound 97 dodge cummins-10675722_10201660807640335_131981652973910476_n.jpg
Old 10-27-2014, 08:05 AM
patdaly's Avatar
Ouch.
Old 10-27-2014, 08:16 PM
gorms's Avatar
Just curious....how many miles on that trans, and did you pull heavy with it?
Old 10-29-2014, 08:51 PM
dougcarlo's Avatar
Just bought a rebuild kit for my nv4500 from quad 4x4, pretty spendy.
Old 10-29-2014, 08:57 PM
how many miles around 370k
it has around 370k that i know of with the 5th gear nut upgrade and the first owner pulled a Little Debbie trailer and the guy before me was a retired logger and me i havent done much towing with it as i did in 2012
Old 10-29-2014, 08:58 PM
rebuild kit
what brand of kit did you go with?
Old 10-29-2014, 09:07 PM
dougcarlo's Avatar
The part number QK-1033, has everything but gears. $850.
maddddog
10-11-2013 11:35 PM
samiam4
12-19-2012 12:08 PM
capitalfear
12-27-2010 08:35 PM
ProjectM880
12-01-2004 06:40 PM
Quick Reply: HELP 3rd gear sound 97 dodge cummins
