What is an HX35 capable of?
Old 07-10-2014, 07:21 PM
19mike92's Avatar
So there's a rebuilt hx35 on craigslist for cheap. Just wondering if this would be a major upgrade over stock? What injectors should I run? How much boost would it make and what hp will it hold?
Old 07-10-2014, 09:13 PM
Received 1,332 Likes on 862 Posts
From what I've read, they are good for about 25 lbs of boost. And will support to about 250hp? Your stock injectors should be fine up to about there I think?
This is just info I have garnered...never really researched it.
Old 07-11-2014, 07:21 AM
Philip's Avatar
HX35 is good for 35 PSI. Anything above that is just overheated air.
A 35 isn't much of a step up from your H1C. You can out grow both real fast and easy.
Old 07-11-2014, 08:44 AM
mknittle's Avatar
It will spool faster than a stock H1c
Old 07-11-2014, 09:01 AM
sooty's Avatar
especially with a smaller exhaust housing
Old 07-11-2014, 09:08 AM
gyman98's Avatar
I agree with 250hp and with a removable exhaust elbow and 12cm2 housing it's a good turbo for a lightly modded engine. 30psi is about its efficiency threshold
Old 07-11-2014, 09:52 AM
PapeCAT's Avatar
One overlooked benefit of the HX35 is the existance of the Map Width Enhancement slot. It will prevent compressor surge in high fuel, low rpm low boost situations.
Old 07-11-2014, 11:03 AM
19mike92's Avatar
What about a stock turbo off of a newer 24 valve or common rail?
Old 07-11-2014, 11:25 AM
Rick 12v CTD's Avatar
If I'm not mistaken the 24v turbos will either be hx35s or hy35s. The hy has a 9cm housing.
If the hx35 is cheap I'd buy it. They are good 35-38psi, will spool faster, have the MWE slot and are happy around 250hp but can actually make a fair bit more than that.
Sent from my SGH-I747M using Tapatalk
Old 07-11-2014, 01:52 PM
Bob Beauchaine's Avatar
My PDRHX35 is a modified HX35 purchased from PDR (Piers Diesel Research) when it was owned by Piers Harry. I was told not to go over 35 psi except on rare occasions. The most I have seen was 38PSI. You can look at my sig. I have been over 300 RWHP since 2003.
Bob
Old 07-11-2014, 05:37 PM
19mike92's Avatar
Looks like I'm going to pick it up this weekend. Will the stock injectors be ok? I'm think it just won't smoke as much considering I have the stage 2 fuel pin. Will the factory intercooler pipes mate up to it?
Old 07-11-2014, 05:52 PM
You might have to re-clock to make it hook up but it should work.
Bob
Old 07-11-2014, 06:06 PM
BILTIT's Avatar
Stock injectors are fine, i still run them at 40psi with my commonrail turbo.
Old 07-11-2014, 10:54 PM
19mike92's Avatar
Is it much to install. Or will it be pretty much a bolt on deal?
Old 07-12-2014, 12:08 PM
BILTIT's Avatar
hx-35 should be pretty much a bolt on. You might have to move your downpipe back an inch.
Quick Reply: What is an HX35 capable of?
