ISB CM2150 Changes And Overview
Old May 17, 2007 | 06:33 PM
Monty's Avatar
{From Admin}
This article has been moved...
Click here to proceed.
Old May 17, 2007 | 09:55 PM
gsbrockman's Avatar
Very educational & informative post........wow, no lift pump !
Greg
Old May 17, 2007 | 10:01 PM
PourinDiesel's Avatar
Greg
Not on the engine...hasnt been one since 05 model year.
Old May 17, 2007 | 10:03 PM
Monty's Avatar
I edited the overview. From my sources in a meeting with Cummins, I was told that all 6.7ltr applications did not recieve a fuel lift pump since they were not needed due to the gear pump/high psi lift pump able to pull its own fuel. I can tell you that other applications outside of Dodge DO NOT use a lift pump.
However, it looks like Dodge did in fact go ahead and install a pump in the tank.
Sorry for the confusion
Old May 17, 2007 | 10:10 PM
gsbrockman's Avatar
For a minute there Monty, you had me thinking I'd lost it !
Greg
Old May 17, 2007 | 11:08 PM
zontral's Avatar
Cool, Thanks for posting, I've been looking for some info like this for awhile.
Old Jan 26, 2008 | 07:30 PM
realoldandcrust's Avatar
How does the operator actually know when a regen is needed or in the process?
Old Jul 16, 2008 | 01:18 PM
Hopper's Avatar
A regen should be running almost any time you have your foot on the gas pedal. Works best if engine RPM is over 1200. If you have the cruise control on, regen will not occur. When your catalyst starts to get full, you will get a warning on your overhead, with a percentage starting at 70%. All you need to do is run your truck down a highway controlling speed with the gas pedal. On a full catalyst, it will take 30-45 mins to complete the regen cycle and clear out the catalyst.
Old Oct 5, 2008 | 01:13 AM
DieselLady's Avatar
OK, What's DOC stand for???? Please!
Old Jan 6, 2009 | 09:05 AM
XLR8R's Avatar
Diesel Oxidation Catalyst
Old Jan 6, 2009 | 09:55 AM
DieselLady's Avatar
Thanks!
Just one thing I would like to add to that article. Just to clear things up a bit.
"Passive" regen is what goes on pretty much when ever you have your foot on the throttle. Active regen happens much less frequently and only when the computer sees the need. For example in very cold climates, the truck will go into Active regen much more than it will in say Florida. THis is due to the fact that the exhaust can't maintain the heat needed to do a passive regen.
Also, I know, well at least on my truck it won't regen in park. I have questions about weather it will regen in cruise control or not. I would think that it would due to the fact that you can go for hours in cruise and I doubt they would shut it down for that long.
Also, maybe this is nit picking a bit, but just because the overhead says Cat full, doesn't necessarily mean that you need a new DPF. If it is truly clogged, well yes you will because they are not cleanable, BUT!!! If the truck is running well, then most likely it is not clogged! There are cases where the computer thinks it is clogged, usually when it can't see the EGT or O2 sensors and it will not regen for a long time. Usually around 80 to 100 miles. It will derate the engine, to help save the DPF but if the DPF is still clear you can reset the computer to default settings and it will be fine. The reason I bring this up is that the truck doesn't really make much soot at all and can go considerably farther than 100 miles before it will clog even without regenerating.
Like I said, Just an FYI.
Old Mar 8, 2011 | 07:49 AM
jdinny's Avatar
Great info
Old Mar 8, 2011 | 08:46 AM
Tobin's Avatar
What does CM2150 stand for?
Tobin
ABDTR #5
Aug 26, 2008 04:04 PM
dieselfuelonly
Jan 26, 2007 11:11 PM
Begle1
Apr 21, 2006 03:55 PM
possum
May 24, 2005 11:30 AM
