Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Add hydrogen for better mpg
Old Aug 28, 2009 | 02:32 PM
  #586
CamperAndy's Avatar
Actual thermal efficiency is around 35 to 40% when cruising steady state.
Old Aug 29, 2009 | 02:52 PM
  #587
annabelle's Avatar
Originally Posted by slowflyer2112
I understand that I am not producing it. We know how much we can produce with some of the well engineered systems available and we know what the current draw will be with those systems, what we don't know is what amount of hydrogen injection is best under what conditions. If we knew this and graphed it out, then all we would need to do is match up a system to cover those needs for the best results and we could also end the argument about whether it works or not. I already know that it will work based on chemistry and what happens during combustion, what I don't know is how well?
I also know that it will cost some energy to make the hydrogen, the question is how much will it cost in relation to the slight gain we might make.
Remember that internal combustion engines when cruising down the hwy at light throttle are only about 6-10 percent efficient in relation to the amount of fuel (btu's) burned and if we get a 20-30% gain the that's only 20-30% of the original 6-10% efficiency we started with.
There is no debate on weather hydrogen improves fuel mileage. The debate is weather hydrogen can be produced efficiently by the engine in order to provide it to increase fuel mileage. What would your experiment prove......a given
Old Oct 13, 2009 | 01:57 AM
  #588
6spd05Dually's Avatar
Off the topic for a sec madam, but do you wear glasses and a white lab coat as you post on this thread? Those types of women can be very hot!
Old Oct 13, 2009 | 02:19 AM
  #589
annabelle's Avatar
Actually, I'm not a woman, and I don't swing your way.
Old Oct 13, 2009 | 02:23 AM
  #590
Transgendered huh.....annabelle is usually a woman's name. Just saying!
Old Oct 13, 2009 | 02:28 AM
  #591
annabelle's Avatar
Name of truck......been happily married to the same woman for 27 years.......I guess its true about what they say about assuming. Now that we have my sexuality determined, do you have anything to add to the discussion?
Old Oct 13, 2009 | 01:32 PM
  #592
XLR8R's Avatar
dadgum prevert...
Old Oct 13, 2009 | 01:53 PM
  #593
RowJ's Avatar
There is no debate on weather hydrogen .....
Hey....it's raining Hydrogen.
RJ
Old Dec 15, 2009 | 08:58 AM
  #594
whgoose09's Avatar
whgoose
The discussion about HHO (Hydrogen). Go to Ad removed it will explain hho.
Yes it does ad fuel economy. Yes it cleans up to 80% of your carbon from the engine and gives it new life. Increases your bottom end power about 20%. Many good things.
Someone wrote that it takes power from the engine to make system work. Making these system work (if done properly) takes negative amount of amp draw from your alternator. Hoped this helped.
Old Dec 15, 2009 | 09:10 AM
  #595
CamperAndy's Avatar
Originally Posted by whgoose09
The discussion about HHO (Hydrogen). Go to (Ad removed) it will explain hho.
With negative amps from the alternator, does that mean it makes amps??
For a first post it looks like your advertising and also have no idea how the underlying physics work.
Old Dec 15, 2009 | 09:12 AM
  #596
whgoose09's Avatar
There' one in every crowd.
Old Dec 15, 2009 | 09:19 AM
  #597
CamperAndy's Avatar
Well goose the ball is in your court as your second post did not enlighten anyone. Come on and give us YOUR first hand expertise on the subject. I am sure we can help you to understand.
Old Dec 15, 2009 | 11:42 AM
  #598
whgoose09's Avatar
whgoose
I did not mean anything like what you suggest. I was really saying that it takes a small amount of amps from the alternator to run a hho unit.
What exactly do you want to hear? It would take quite awhile to explain the whole process. As far as Cummins 5.9 or 6.7 it works when installed properly.
Old Dec 15, 2009 | 01:53 PM
  #599
CamperAndy's Avatar
Well there are almost 600 posts and 62,000 views on this thread. I think this horse has been beaten but if you really think that you have a fresh point of view that will work then post away. Just linking to a sales site is really poor form since they are not sponsors of this site.
Old Dec 15, 2009 | 02:07 PM
  #600
whgoose09's Avatar
whgoose
Read the web site it explains the hho units and how they work. If your just looking for an argument try someone else. All I was doing was to try to help. I'm not hear to argue with someone who obviously has nothing else to do. I won't bother you or the others. Sorry for wasting my time as well as yours.
Good bye and good luck.
